P100D: what's your 90% and 100% range?
Discussion in 'Model S: Battery & Charging' started by Patroradio, Mar 5, 2017.
  1. Patroradio
    Patroradio Member
    Montreal, QC
  2. sdorn
    sdorn Director of Awesome
    Georgia
    My 90% tops out at about 285 or 286 and my 100% is usually 316. It hit 317 once.
  3. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    Houston, TX
    AP 1.0 P100D
    At delivery 9/2016: 283.96 @ 90% (~41 mi on the odometer)
    2/2017: 316.77 @ 100%
    3/3017: 283.3 @ 90% (~4800 mi on the odometer)
  4. sdorn
    Georgia
    I will note that my 90% number fluctuates from day to day, and you really have to catch right at the instant it finishes charging because it immediately starts dropping again as the charger cuts off. You need to be there the exact second it finishes to get an accurate number, and even then the number is subject to be different depending on how much amperage you were using to charge the car, temperature, and whatever other random factors affect it. I think the 100% number is more important in any event, but again you need to catch it the exact second it stops charging.
  5. Mark Z
    Mark Z Active Member
    North Orange County
    If you set your Tesla app for notifications when it finishes charging, the accurate number will appear on your phone after every charge.
    BTW, my just delivered new MS 90D manufactured this month has 264 at 90%. Congratulations to those who have a 100D.
  6. sdorn
    Georgia
    Good tip! Thanks.
  7. TexasTeslaRacing
    North Dallas, Texas
    2016 P100D 290 90% 321 100%
  8. yamanote
    yamanote Member
    Vancouver BC
    463km/288mi @ 90%, odo 9200km/5700mi.
    516km/320mi @ 100% approx 2500km ago.
  9. evomatt
    evomatt Member
    uk
    What are you guys quoting as on my car it says rated and typical (im in the UK)
    I just picked up my used P100D with 9500 miles on it and it had 86% charge at collection Rated said 317 typical said 253 is typical based on previous usage? and Rated a drive like a grandma figure?
    Also am i right in thinking if rated was 317 at 86% then at 100% it would be 369 based on 317 divided by 86 times 100? Or does it not work that way
  10. bigdaddie
    bigdaddie Member
    Chowchilla, CA
    I'm almost exactly the same.
  11. sdorn
    Georgia
    In the US and our range is quoted as "rated" which is based on the US government's EPA test cycle. There is also an "estimated" range and an "ideal" range that we can see. I think most people ignore those numbers as "ideal" isn't achievable and "estimated" fluctuates based on your recent driving. The "rated" number is what all EV makers in the US use to advertise the range on cars here.
    Maybe someone in the UK can speak up and explain how the range numbers work over there.
  12. sdorn
    Georgia
    Happy to report that after 11,000 miles and almost 10 months of ownership I haven't seen any battery degradation. I still get around 285 or 286 at 90% and around 317 and sometimes 318 at 100%.
  13. quenbo
    quenbo Member
    Belgium
    In Belgium, I have, after 4000 kms, a typical range of :
    482 km at 100%
    434 km at 90%
    Typical range seems to be calculated on a 180 Wh/km basis
  14. quenbo
    quenbo Member
    Belgium
    After recalculation it seems to be a typical 90 Wh/km
  15. Model S M.D.
    Houston, TX
    Update with ~10,500 on the odometer.
    281.38 @90% (283.96 @90% on initial delivery)
  16. MAPC
    MAPC #158
    Woodside, CA
    285 @ 90% after 6500 miles
  17. zanary
    zanary Member
    San Francisco, CA
    317 @ 100% SOC - Model S P100D and only 30 days old with under 1400 miles.
  18. Whiterabbit
    Whiterabbit Member
    Long Island
    Looking at a 2016 p100d with 90% at 267 and 100% at 301. 24k Miles. So about 5-6% range degradation.
    Should I be worried?
  19. Model S M.D.
    Houston, TX
    That seems excessive, but could be due to cold weather? I have a 2016 P100D, recently did a 100% charge at 314 miles, at delivery was 315). I've got about 14,000 miles on the odometer.
  20. sdorn
    Georgia
    I think that is excessive as well. I have a December 2016 P100D with about 19,000 miles. I charge to 315 at 100% and 284 at 90%. New it was 318 at 100% and 285 or 286 at 90%.
