I realize this is an "older" thread, but I just discovered it, and I am currently interested in the rear wheel size difference.
Background (for my benefit and for readers not familiar with wheel/tire information)
Tesla wheel rim nomenclature, such as "
20x
10J +
35mm," means:
- 20-inch diameter (point on edge of bead seat to point 180° opposite on edge of bead seat)
- The "bead seats" are the protruding circular edges of the outer and inner faces of the wheel that help grab and secure the beads (inside edges) of the the tire.
- 10-inch wheel width (from outer bead seat to inner bead seat).
- 35mm wheel offset--"the distance from the [inner] mounting surface of the wheel [where the lug bolt holes are] to the wheel's outer-inner center-line, given in millimeters." (from America's Tire website)
(America's Tire) ------------------------------------------ (Les Schwab)
As we may know (or have found out the hard way), it is very important to select the correct wheel sizes--diameter, width,
and offset--so the the wheels do not rub or otherwise interfere with brake, fender, and suspension components. In addition, these can dimensions affect the aesthetics (appearance) and ride of the car, and can also have major impacts to handling and safety.
Model X apparently always had "staggered" wheel sizes, (in this case) meaning that the rear wheels were designed to be slightly wider than the front wheels.
Apparently, earlier (~2016) Model X came with 20x10J +35mm rear wheels? Then at some point (~2017) they switched to 20x9.5J +40mm wheels?
Modified from Les Schwab website figure.
(Not fully to scale and not truly representative of Slipstream wheels.)
I suspect, but do not know) that this change was made to reduce the likelihood of wheels/tires rubbing on other components. Nonetheless, there are plenty of older (used) Tesla Model X and new aftermarket 10-inch wheels still in the marketplace.
The current Tesla Parts List indicates that new replacement 20-inch Model X wheels are:
March 2021 to present (for comparison)
- 20x9J ET40 - front Cyberstream (I believe ET ["einpresstiefe"=insertion depth] 40 = +40mm?)
- 20x10J ET35 - rear Cyberstream
2015 to February 2021 ("Legacy" or "Classic" Model X)
- 20x9.0 ET35 - front Helix
- 20x9.5 ET40 - rear Helix
- 20x9.0 ET35 - front Slipstream (three color variations)
- 20x9.5 ET40 - rear Slipstream
As stated above, I believe rear wheels were 20x10 +35mm at an early point in the history. Incidents of rubbing(?) or some other technical issue may have necessitated a small modification?
I am no expert. From what I can tell, dealing with changes to wheel and tire sizes can be tricky, especially the further one ventures from stock specifications. In looking at used wheels and tires for sale in my area, I have already seen evidence of poor choices made (e.g., rear wheels installed at the front leading to worn grooves on the inner wheel rims.
Furthermore, with its air suspension and control settings Model X has the capacity to change vary ride height (which can affect wheel/tire positioning, possibly cause rubbing(?), and also negatively affect tire wear.) Unless you
really know what you are doing, for safety's sake I recommend that folks stick with current stock specifications on wheel and tires.
The OP Issue
I cannot predict how deleterious, if at all, it is to be outfitted with 20x10 35mm
and a 20x9.5 40mm rear wheels at the same time. If this had happened to me I would be examining:
- Original rear tire wear.
- Any evidence of rubbing on either side of the undercarriage.
- Online information.
Regardless, I assume that this is
not something one would normally want (Even though the size difference may be considered minor?). So I am interested to hear:
- How you made out with Tesla Service?
- Whether you were able to replace one of the rear wheels?
- What the final outcome was?
Hope things all turned out OK.
Buyers looking at aftermarket and used Tesla wheels and tires: BEWARE!
In my experience, this is one of the most danger*-fraught areas for Tesla (and autos in general) consumerism. There is a TON of misinformation, both accidental and purposeful, out there. Especially on the Internet, but even at otherwise legitimate brick-and-mortar establishments. Be extremely careful when buying used and new-old-stock tires from private sellers and used tire/wheel dealers. Likewise, do your homework
before investing in aftermarket and (claimed) Tesla wheels. It is a (tire and wheel) jungle out there!
______
Meaning the chance for misinformation, and hence for resulting poor purchases, is higher than normal. Since we know that--as the contact point between the car and the road--wheels and tires are so important, this situation is troubling. It is interesting to note that something like at least 40% (last time I looked) of all TMC Classified ads are concerned with tires and wheels.
