Here is a video from an Autocross event I attended. Car performed very well even with the stability on. OEM tires, no mods.
Pax Time Results
Finished eighth in PAX, first in class.
"with that display" not sure what that means?
Miata FTW!Here is a video from an Autocross event I attended. Car performed very well even with the stability on. OEM tires, no mods.
Pax Time Results
Pilot sport cup or the stock pilot super sport 4s?It is a P3+ so I was running on the Cup tires, that being said, the people in front of me were running on 200 tread wear proper autocross tires. There were some good drivers and very well prepared cars at this event. The video was one of my earlier slower runs, kept forgetting to turn on camera. I was amazed how much the stability control let me move the car around. The one complaint I had was when you rotate the wheel past a certain point it is like an off switch for power. This really hurt my times in the two slow sweeper corners, I could not get the car to rotate. I tried going in slow, tried tossing it into the corner, it just doesn't like high input angles.
I have only had the car for 4 days so have made no changes. I plan on putting as much camber in the front as I can get, some 19" wheels with wider proper autocross tires. Give me track mode and this thing is going to be a beast.
There is no camber adjustment front or rear on the Model 3. How much outside edge wear did you get?
Mountain Pass Performance makes adjustable camber links for the rear but there's nothing for the front. That wear on the sidewall doesn't look great! Hopefully someone will come up with some sort of solution. You can dismount and swap the tires to get a bit more life out of them once the outside edge wears off.Sorry, 4s. I have been told you can get some camber, still looking into it. I ran the pressures at 45 to try and lessen the roll and avoid to much abuse to the edges. All and all not bad edge wear considering. I will try and get a picture up.
