Do you like? How do Endless compare to what you tried so far? What pads have you tried?
Pros:
They are magical. No fade on them compared to stock. Have not tried other pads, because I spend a lot of time chatting with
@mcbarnet007, and up until these pads, his feedback had been mixed with other pads (3 or 4 different manufacturers). Knowing how frequently he's on track, and how hard he pushes the car, if he was praising the pads, I felt it was worth a shot. They are also pretty quiet on the street, with only a squeak here and there.
Cons:
- The rear pads rattle like all heck unless you add the stock shim. This is quite annoying, and even embarrassing during daily driving. I've had time to replace one shim, and it helped quiet that side. I will do the other side this weekend. It takes a bit of elbow grease to remove the shim from the stock pad, and you'll need to hammer the shim flat.
- Biggest issue - the are far too close to the Mountain Pass Performance Rotor hats. Without the shim, they rattle, so they can make contact with the rotor hat. Once the pad material wears, it's even more likely to contact the rotor hat. I gave feedback to the supplier, and they seemingly don't care. The only response I got was that they designed them to work with the stock rotor, so MPP's rotor must be different in size...
- Real dusty. Though I'm sure MPP's slotted rotors contribute to pad wear, and thus an increase in pad dust.
Overall, I like the quality of the pad properties.But I am hesitant to recommend them if you are not on stock rotors.
You can see the closeness here:
And it actually made contact at some point:
Paint missing from the rattle, rattle:
***PSA***
You can retract or extend the EPB piston by hooking up 12v power source to the contacts inside of the plug of the EPB motor. On the Performance red caliper the plug is square on one side. To retract the inner piston, connect (-) ground to the contact close to the square side while connect (+) to the contact at the round end of the plug. To extend the inner piston, switch the polarity. There is no auto stop on the motor, so pay attention to the sound of the motor when it is at end of its travel on retraction. Break the circuit when you hear the sound change.
Awesome. I was going to do this when adding a shim to the Endless pad, but I was also short on time, and didn't want to mess something up. I still need to shim the other side, so I will definitely do this.
