P3D+ misc info and pics- wheel weight, calipers, suspension
SD_Engnr
1,836
1,491
San Diego
Well, that was awkward... I went to install my 19" aftermarket wheels (Wedssport SA-67R w/Michelin PSS) that were collecting dust in the garage, and I ran into a bit of a problem with them not fitting. Model 3 wheel studs are 14mm, but my Infiniti are 12mm. It turns out that the mounting holes of the wheels were not meant for larger than 12mm. Doh! I should have looked into this ahead of time! I really wanted to run this set up as I love the look, and they're a minimum of 8 lbs lighter. Anyway, on to the info I gathered and some pictures I took.
Wheel studs: M14x1.5
20x8.5 w/tire weight: 52.5 lbs
Rear rotor thickness: 20mm (.787")
Front rotor thickness: 25mm (.985")
Rear half shaft thickness: 25mm (.985")
Front half shaft thickness: 25mm (.985")
Hub ring: 64.1mm (2.523")
These were gathered with a caliper that measured in imperial units.
Did not get rotor diameter...
Attached are photos because why not?
AH, so that's how they made the front half shafts fit through the strut:
Not a whole lot of room here:
Random:
e-FTW
New electron smell
Aug 23, 2015
3,288
3,109
San Francisco, CA
I see the suspension gets real close to the wheel, much like on the Model S. Any thoughts on possibility of using snow chains (because California)? On rear wheels only.
SD_Engnr
1,836
1,491
San Diego
Noooo. I have wheels for my car as well and I bet I am going to have the same problem..
Go measure the lug holes and let us know. My goal this week is to find a machine shop that can safely open these up. Once I do that, I'll weight the cost of keeping these vs selling them and buying a new set.
gtmotor
218
328
Arizona
I've been waiting for a thread like this! Can you do the community a huge favor and see if there is any difference with the overall suspension design vs the standard cars? BMW M series cars have significantly different setups. I'm going to be a little disappointed if only the springs are different.
The weight zip tied to the control arm is probably some sort of harmonic damper. My Lotus likes to dynamically lighten itself (a nice way of saying parts like to fall off) so I've been slowly replacing fasteners through the years and loctiting them. Any car that sees regular track use could probably benefit from that...
SD_Engnr
1,836
1,491
San Diego
I can take more photos, but as far as I can tell, there's little change in the suspension setup. Of course, to qualify that statement, I'd need a RWD 3 to inspect/measure against.
As I said above, if there's a specific request, I'll take more pictures.
FlatSix911
Porsche 918 Hybrid
Jun 15, 2015
6,629
6,042
Silicon Valley
Can you not have the stud holes on the wheels drilled to 14mm? I'm not a mechanic, have no idea if the consensus is that's unsafe.
I plan to explore this option, just need to find a reputable place to do it.
A good machine shop can drill the holes from 12mm to 14mm very easily. Are your Infiniti wheels hub centric @ 64.1mm?
Reactions: SD_Engnr
SD_Engnr
1,836
1,491
San Diego
No. I think the Infiniti is 66.2, and I think the wheels themselves are 72.6 or so. If I keep the wheel, I'll source some hub centric adapter rings.
Amp3d
36
40
North Carolina
If you are able to get it, the rotor diameter, and the radius from the center of the hub to the outermost point on the brake calipers front and rear would be helpful. I’ve ordered the performance package with the 20” wheels as well but I’m interested to know whether certain 19” wheels will clear the brakes.
Thanks for taking the time to post this information for everyone.
