jaboki
@Brian N,
You’re right.....that lip is still there.....so it’s got to be a rotor thickness issue.
Ski
Weird that the rotor hats would be thinner than the regular models. I guess that means that the track is slightly narrower on the P+? Seems like spacers are the simplest solution.
Yea... So the PUP has thinner rotors.
Spacers are simpler but my worry is the shorter lug nut stud based on @FlyNavy01 comment: "I also only got 7 turns when torquing these lugs down with my wheels, and the rule of thumb for minimum thread engagement is the same depth as the diameter of the bolt (14mm in our case), which corresponds to ~9.33 turns."
