P3D Rear not aligned mystery
Schmollak
28
11
Richmond B.C. CANADA
Has anyone had their rear subframe adjusted to fix any uneven poke? this is a continued search for why my rear left pokes and right rear sinks. Tesla put my car on alignment and was within spec. So im thinking the whole subframe is shifted left.
My issue is that the rear left wheel pokes and rear right wheel sinks. Swapping wheels around and using 3 different sets of wheels produces the same result!
Possibilities include fenders not properly aligned, including rear bumper..
or the whole rear subframe shifted.
Or .. im out of ideas! quite frustrating as I cant not notice one side pokes!
Schmollak
28
11
That is very strange, I have not heard of that before. Can you post images?
MasterC17
1,058
1,714
this exact situation but on rear p3d
You likely just have more camber on one side. Stock alignment specs allow for a fair variance on camber in the rear end. It's not adjustable, so it kind of is what it is unless you want to purchase adjustable arms. It's not going to negatively affect the vehicle.
Reactions: Schmollak
MasterC17
1,058
1,714
Hmm, your toe is arguably more concerning and could also change the "look". Fortunately, that is adjustable.
It's extremely unlikely the frame is off-center. It's possible your subframe is damaged, but not likely. It is also possible you have damaged suspension arm(s), but your alignment does not indicate such.
This sound silly, but considering you appear to be running aftermarket wheels, have you confirmed they are the same size in the rear (a possible shipping mixup or staggered setup)? Are you running spacers or hubcentric rings?
Schmollak
28
11
I've swapped wheels opposite sides. Stock wheels and winter wheels. All same results. My wheels also are huncentric so no spacers or hubrings
MasterC17
1,058
1,714
Well the quarter panels are not adjustable. You could try shifting the subframe (there are four bolts, 21mm bolts I believe), but you would need it on a lift with someone experienced. They could also inspect the subframe and arms at the same time.
lbowroom
413
322
Orange County
I have a difference left to right on my car too. On coil overs it’s easier to see as I’m dropped about 1.25” and my wheels are spaced near flush. I initially blamed camber as well. It’s maybe 5-6mm different side to side, which means the fenders are 2.5-3mm off perfect center to the subframe. This doesn’t seem to be an abnormal tolerance.
Schmollak
28
11
Did you ever fix it or left it
lbowroom
413
322
Orange County
No, I think a 2-3mm offset of body to running gear in a car is perfectly acceptable. I don’t know how far yours is out. Do you have a T-square or a level? Hold a level on the fender and measure to the top of the wheel on either side.
can’t believe you swapped 3 different wheel sets? You thought there would be a variance in wheels?
have any pictures?
Schmollak
28
11
have any pictures?
Nah I have 3 sets and I just swapped em around to diagnose the issue. Don't have any leveling stuff atm. I think its about 5mm different. If I put a 5mm spacer on the sunken side then it visually looks the same
James Cole
41
16
Texas
I had this issue on a new BMW M4 on the rear, subframe was shifted left, put car on lift with my trusty mechanic loosened bolts and centered subframe.
When we removed the first bolt it was obvious the subframe was shifted because the edge of the bolt was on the far side of the subframe hole.
No damage it came that way from the factory.
