Primary questions:
On my 2014 Model S P85 with air suspension I have a slow leak that is likely coming out of the bottom of the right rear air spring bladder. I see evidence of the air leaking when spraying a soapy solution on the joint between the damper body and the rubber dust boot. Has anyone ever taken one of these air springs apart and replaced the internal seals? I was waiting for Suncore to get some rebuilt units in stock but they have been out of stock since June.
Alternatively, I'm looking at putting on a set of Arnott rear air springs that are listed for the AWD 2016-2018 model years. Is anyone familiar with the interchangeability between older and newer part numbers? Has anyone had the newer part numbers put on as part of a service on an older vehicle? I have a quote from a Tesla service center that indicates they plan to put on part numbers 6006352-07-B and 6006353-06-C if they confirmed that my air springs were indeed leaking. I believe my original parts were the 6006352-00 and 6006353-00, but I did not confirm when I was inspecting for leaks.
Thanks,
Joel
- Has anyone ever taken one of the earlier air springs (6006352/3-00) apart and replaced the internal seals?
- Can anyone confirm interchangeability between older and newer rear air spring modules?
Thanks,
Joel
