I've spent many hours correcting toe after the service center does an alignment. They get it wrong (very wrong) every time. Worst I got back was 0.8 dgrs toe out (yes OUT) in the rear. It obliterated the 21s. This last time I got it back with exactly zero rear toe. I set it to 0.2-0.3 dgrs toe-in rear and a hair toe-out front.
Here's a post I made showing how to measure toe yourself:
How to measure toe yourself (with pictures)
how many miles have you been running with this and hows your tire wear?
I've gone through a couple sets of tires. The extreme inner edge wear is gone. It still wears a bit more towards the inner side due to the camber (which is non-adjustable), but it's not that bad.
Bad part is even with the alignment fixed I only get 8K miles out of the rear and about twice that from the fronts. I think I'll ditch the 21's and go with 20" wheels instead.
The stock specs work well for me, 20K miles and probably 10K left. Perfectly even wear. From the factory the front had too much toe in so we took Nicki back at 2K miles for that and other minor adjustments. They got it dead on, verified it with another shop who I told NOT to align, just check then watched him to be sure all surfaces were clean and he knew what he was doing (Sears).
Wheel alignment takes time and skill. Usually the alignment guy is under pressure to get the cars out and will miss dumb things that make the machine read incorrectly. Garbage in, garbage out as they say.
im not too worried about camber wear, that isnt what eats up the tires but wow only 8k on the rears? what tires are you running? is this a P85D?
with the stock alignment specs, the rear tires are getting destroyed on the inner side due to the positive toe in the rear, they also run negative toe in the front.
anyone tried to zero out the toe front and rear?
thoughts/experience?
When camber gets between -1.8 - -2.5 it wears the inside tread out faster. Having your camber at -1.5 - -1.7 improves the tire wear but you loose a bit of performance but lets be honest the Model S really isn't the best track car.Can you experiment with tire pressure? No expert here but doesn't negative camber wear out the inside more than positive or neutral?
https://www.townfairtire.com/webimages/camber.gif
