The 'motor power' is simply the max power the motor can make at a given system voltage (in this case the larger battery pack is the reference voltage level). The motor outputs max power when it hits 50% efficiency. Apply more power any all you get is more heat and less output.
The P85D and P90D do not have the same motor front and rear which means the power curves are very different. This is a good thing. Why would you want to align the power curve and stress the battery with a single huge peak in the power draw? The smart thing to do is to broaden the peak power by draw giving higher overall average acceleration and lower peak battery stress. This can be done by differing the motor wind or size or by differing the gearing F/R.
The reason Tesla has not been clear is because no other AWD car has two motors so it is not apples to apples.
