P85D (E battery) maintains high charge rate longer?
Discussion in 'Model S: Battery & Charging' started by Matias, Jan 4, 2015.
  1. Matias
    Matias Active Member
    Finland
  2. docgarner
    docgarner Member
    Clearwater, FL
    Seemed that way on mine the other day. I took it to the nearby supercharger and it was putting out > 100amp at 350V until right toward the end.
  3. yoyo
    yoyo Member
    IL, USA
    do not know if it is display error or what. But with 90 miles rated remaining, the charge started at 368v 280A ! (196miles/hour).
    I charged it to 85%, and it was still around 103A toward the very end. It took less than 30 minutes to charge to 212 (added 122 miles).
    I did not check what was the charging rate in between, as the car did not want to wake up with mobile app.
  4. Bighorn
    Bighorn Former Top Supercharger
    Big Horn, Wyoming
    Haven't seen anyone document rate constant for the number of Watt-hours per rated mile added at a supercharger. I realize this has been changing weekly as firmware raises the rated range, but it would be nice to be able to compare with the 300Wh/m rate of the P85.
