Andyw2100
This is correct.
Thanks for the confirmation.
I knew that, which is why I asked Sorka for his source of information that stated the maximum pressure of 51 psi should not be exceeded even when hot.
This is correct.
I agree.
And the communication even after the fact is not consistent.
My all-seasons came back, after being installed, inflated to 48 PSI. When I asked about it, the SC said the recommendation was "45 to 50." But the thread I referenced, or others on the topic, say the door stickers are now stating the minimum cold pressure is 50 PSI.
Where are you getting that information?
Everything I have read indicates that the maximum pressure is always the maximum to inflate to when the tire is cold, and that it is understood that the pressure will be higher than that when the tire heats up.
Working in a tire shop for two summers. Normally filling the tires to the specified pressure for the vehicle load cold would be just fine because the vehicle specified pressure is never anywhere near close to the maximum inflation pressure. If you fill the tires at to 50 psi at 40F and then drive in 115 degree weather(and these swings can occur in Arizona), the tires can heat up to 130+F and your pressure will increase 15 psi. Do you want to be driving around on tires inflated to 65 psi? If you do, then go right ahead but make sure you put up a sign so everyone knows to stay way way behind you.
And that would be perfectly fine. Tire manufacturers take that into account when designing the tire's capabilities.
It seems obvious to me they raised it to 50 to lower rolling resistance and to squeeze more miles out of those little electrons. No other luxury car of same size has that high a tire pressure that I am aware of.
No, 51 psi is actually a common maximum cold tire pressure.
But what he's saying is other car co's don't use these pressures. I don't know of any either, and would agree 50psi gives up ride, for range.
