The point was they were sued for overstating horsepower. You shouldn't expend so much energy trying to defend trying to defend POTENTIAL HORSEPOWER. Like I said....even ICE are tested & can potentially make more HP with upgrades but automakers are not allowed to mislead the consumers by advertising that the motor could potentially produce more HP if only.................
Furthermore, for those defending Teslas misleading advertising due to the ECE R85, here is an important stipulation which should put this all is to rest....
- 5.0 TESTING PROCEDURE
- 5.1 Bench Dynamometer procedure
5.1.1 Auxiliaries
5.1.1.1 Auxiliaries to be fitted
During the test, the auxiliaries necessary for the [COLOR=rgb(50.196000%, 0.000000%, 50.196000%)]
drive trainmotor[/COLOR]
operation in the intended application as listed in Table-1 shall beinstalled in the same position as in the vehicle.
I translate the "auxiliaries" to be the battery etc. They must be the same as in the intended application which is the actual car being sold. It already has been proven here that the auxiliaries of the car do not allow the motors to produce the advertised 691HP.
