I'm not out to prove anything. I'm really trying to understand the EPA rating. Cars are reportedly using more power. Elon tweeted there will be a fix in the form of a "Normal" mode that will be more efficient. Did they test with an unreleased "Normal" mode to achieve 89MPGe? It does not sound like this addresses the 242 on the Monroney sticker.
The first delivery of a Model S was June 22nd, 2012. We know they can't sell cars without a Monroney sticker. So the EPA test had to have already happened. The EPA values get grandfathered if the car doesn't change substantially. Tesla didn't need to retest until the P85D...
From SAE document J1634 OCT2012 "Battery Electric Vehicle Energy Consumption and Range Test Procedure" (thanks to breser for finding this document):
Full charge is to be established using the manufacturer’s recommended charging procedure and appropriate equipment. If the vehicle is equipped with a charger, that charger shall be used. Otherwise, the vehicle shall be charged using an external charger recommended by the vehicle manufacturer. If multiple charging power levels are available, the vehicle shall be recharged at the power level recommended by the manufacturer. If not specified by the manufacturer, the recharging power level expected to be most widely utilized by end users shall be selected.
Note: October 2012 is when this change was documented, so it had to go into affect after that date.
On Delivery the slider is set to 90%. At least mine was. I'm sure they know what the most common charge setting is. I think it is pretty clear. Road trips are rare. Nightly charging is frequent. The most common setting would not be a trip charge.
We also have corroborating evidence with the behavior of Nissan and the Leaf range change...
Someone else said (on the TeslaMotors forum) they called Tesla and that person was familiar with the issue and said it was a 90% charge. I can't vouch for the validity and can't seem to find the thread. So this is just another unsubstantiated data point...
I'd believe that the EPA let them use 100% charge for testing if... We have the SAE document basically stating that they have to use the most common charging level...
a) Nissan wasn't forced to remove a lower charge rate to NOT have to take a 10% penalty.
b) I could explain away the missing miles.
If the charge was to 90%, I can't explain why Tesla has not communicated this fact. They don't have a great track record of communication in anticipation of issues. Maybe they will...
I've tried to find info on the additional Battery reserve that explains the missing miles without any luck. Most of the info I found was 81.6 KWH of usable battery. This is used with the whm of 308 for rated range. The whm of 278 is ideal range.
If they actually changed the amount of available battery through a software update. I would think there would have been extensive threads about it and I would have been able to find them. The threads I did find had pretty extensive documentation of using this amount of energy.
One interesting piece of data I didn't know is that the dash display shows rated whm with a dashed red line with the rated whm. This would be an interesting number. If it is at 308 we can surmise that some of the battery wasn't used on the test. Either held in reserve or the result of a lower charge. That number should be 337 whm to get 242 miles out of 81.6KWH. Best I could do was this video here.
TESLA MODEL S *P85D* ACCELERATION - YouTube
The P85D can use so much power it is hard to tell if the line is at 308 or 337. There isn't much space between 300 and the 512 WHM average...
There are quite a few theories. At this point I'm still leaning towards the EPA J1634 explanation, with a lot of other changes muddying the waters.
