EarlyAdopter
More than 74 kWh is available. The system will shut down the drive unit when the battery reaches it's anti bricking limit of 3.9 kWh left. Before that, you'll be in the 5.1 kWh zero mile buffer. So in theory, you should be able to hit 76 kWh before it says 0 miles but then you should be able to go another 17 rated miles before the drive unit dies.
This is true, though measuring energy use and available energy in a battery is an imperfect science and so you can't always count on having another 17 miles of range after it says 0 miles on the dash.
Once the first battery module in the pack reports dropping below the bricking limit voltage you're done. Could be another 17 miles, could be 1.
- - - Updated - - -
.Also, this day was very neutral for wind, light and variable. My new favorite wind and weather web page is Windyty; it won't run on the MS Browser, but runs great on an iPhone.
That site is _amazing_. Goodbye AccuWeather, hello Windyty.
