P85D rear oil leak? WHAT
Discussion in 'Model S' started by maddog1762, Feb 18, 2015.
Tags:
  1. maddog1762
    maddog1762 Member
    Rock Hill, SC
    I have a oil leak in my 3 week old P85D. Looks like it if from the rear of the car. I left it sitting over the weekend and the is a 3 inch oil spot on the garage floor from the rear of the vehicle. Anyone else have this problem? I thought there wasn't any oil in this EV
    Thanks
  2. Saghost
    Saghost Well-Known Member
    Delaware
    Well, there aren't routine oil changes, because the oil shouldn't get contaminated. However, the gears between the drive motor and differential (and the differential itself) are in an oil bath I believe. It's possible you have a leaking seal or porous housing. I'm sure Tesla will be happy to take care of it. I haven't read of another case like yours.
    Walter
  3. maddog1762
    maddog1762 Member
    Rock Hill, SC
    They are very attentive to the problem just can't believe a 3 week old car with about 1000 miles is leaking oil. Dang
  4. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Are you sure it's oil? Seems like more likely that its battery coolant.
  5. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    It is possible as there is a small amount of oil in the transfer case. This was reported before, and it was found that another car had parked in the spot temporarily! Just FYI.
  6. maddog1762
    maddog1762 Member
    Rock Hill, SC
    I guess I am not sure as I have never seen battery coolant. It was dark and looked like oil.
  7. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN 65513, Model 3: VIN 1913
    Redwood Shores, CA
    The coolant is kinda blue, I think. Someone did experience a coolant leak well over a year ago.
  8. maddog1762
    maddog1762 Member
    Rock Hill, SC
    Its in my garage, nothing else parks there but my Model S
  9. breser
    breser AutoPilot Nostradamus
    North Bend, WA
    There is transmission fluid. It'll be very much like oil. Tesla only recommends changing it every 12 years or 150k miles so a lot of people don't realize that it's there. I have no idea what type of seal they have on the single speed transmission but that could be what's leaking. I'm sure they'll figure it out for you.
  10. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    Interesting! I'll have to make an appointment for an oil change in 2026.
  11. martinwinlow
    martinwinlow Member
    Herts, UK
    "Its in my garage, nothing else parks there but my Model S"
    Er... other half having an affair, maybe?
  12. Tourman
    Tourman Member
    New Hampshire
    I'm going to go with this.
  13. brianman
    brianman Burrito Founder
    I find it amusing that the theories move from "a new car that might have some details that need addressing" to "marital infidelity" so quickly.
  14. jerry33
    Texas
    Marital infidelity is way more exciting (and typically costs about as much as a Model S).
  15. santana338
    santana338 Member
    Manchester, NH
    It's Friday night. What do you expect? ;)
  16. scottm
    scottm Active Member
    Canada
    Yep, .. specially if it's dark oil... new oil is going to be clear and new looking. Something smells funny here, it might not be your car. Good call!
  17. eco5280
    eco5280 Member
    Country
    Not feeling happy in marriage -> looking for things to fill the void -> new Tesla. Makes sense. (Not talking about OP)
    Agree though - new oil is not black. Nor is coolant.
  18. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    Can you perhaps get the S up on a lift and check the transmission drain plug to make sure it is dry and not weeping?
    At the same time you can probably check the seals and case for any sign of a leak....
    Oh Oh.... (Car 54) .... just saw the movie GONE GIRL.... woooow... devious martial material in that flick... diabolic to say the least catch it if you can, also check out Coherence... amazing flic on alternate reality
  19. maddog1762
    maddog1762 Member
    Rock Hill, SC
    In service right now, so I will update when I know the problem, thanks for the marriage consueling! What a forum, LOL
  20. maddog1762
    maddog1762 Member
    Rock Hill, SC
    side seal on the differential was leaking and repaired
