P85D trip SF-Portland: detailed data on range and charging
MarcG
4,306
6,250
San Francisco
Merry Christmas everyone!
Today I took my first long trip in the P85D from San Francisco to Portland.
The goal of this thread is to dissect the detailed data I gathered on each driving leg and charging session in order to analyze the P85D real-world range.
First, a few common points to all the data points collected:
1. Software version was updated to v6.0 (2.0.81) just before the trip started
2. The trip started with 100% charge showing 252 Rated Miles (RM)
3. I have the base 19" wheels with Michelin Primacy tires
4. My P85D has a sunroof that was fully-closed the whole trip
5. No roof rack was installed on the sunroof during the trip, although I did bring it for later
6. Payload was about 500 lbs (two adults, ski/snowboard gear, etc.)
7. Average speeds are recorded below based on distance traveled divided by driving time
8. The goal was to stay at 10 mph over the speed limit (which varied a bunch) using cruise control
9. My girlfriend drove the last sting and she didn't use cruise control (and drove slightly slower than me)
10. No other stops were made besides supercharing
11. Net elevation difference is in feet
With all that out of the way, here is finally the promised data!
FromToMilesDepartArriveAvg mphAvg tempRM usedkWh usedWh/miNet elev ≠WeatherHeating
San FranciscoCorning SC 172.39:0911:3172.8012ºC/54ºF25074.643326Dry/sunnyNone
Corning SCMt Shasta SC108.712:221:4974.9711ºC/52ºF17652.44823218Dry/sunny21ºC/70ºF
Mt Shasta SCGrants Pass SC118.62:264:0571.884ºC/39ºF14944.3373-2401Wet/Snow/Rain21ºC/70ºF
Grants Pass SCSpringfield SC140.15:137:0972.477ºC/45ºF19257.2408-666Dry/dark21ºC/70ºF
Springfield SCPortland108.77:419:1570.217ºC/45ºF13640.6374-197Dry/dark21ºC/70ºF
And here are the charging stats:
SuperchargerRM startRM endRM chgEnergyChg timeChg rateTemperature
Corning2 (1%)202 (90%)20059.56 kWh0:4972.93 kW13ºC/55ºF
Mt Shasta26 (10%)177 (70%)15144.88 kWh0:3576.94 kW9ºC/49ºF
Grants Pass28 (11%)240 (95%)21263.26 kWh1:0657.51 kW6ºC/43ºF
Springfield48 (19%)175 (69%)12737.90 kWh0:3075.79 kW11ºC/52ºF
Some interesting findings:
A) Charging to 100% yielded slightly over 250 RM, so I based my SOC % calculations on 252
B) The four trips all indicate that the useable energy is 75.2 kWh
C) Overall consumption seems to be around 400 Wh/mi on average
D) Charging until around 50% emits a loud fan noise under the frunk (cooling the battery?)
There you go, hope this helps!
Now, feel free to discuss away :biggrin:
-Marc
I just did that drive myself a few days ago in my Sig P85. I do not have a detailed log, but I recall that while I drove slightly slower (probably averaged 70 mph), more than 50% was in rain, and I averaged about 320 Wh/mi.
Hmmm, it does seem that the P85D is significantly less efficient still at this point.
I dare say, it was a bit risky of you to skip the Vacaville SC and run the car all the way down to 2 RM. The battery calibration can vary. Mine was recently out of whack and I experienced a full shutdown at 2 RM. That is another story to be posted soon...
-Marc
Thanks, Marc!
Does the usable 75.2 kWh include any hidden miles below zero, or is that still a mystery?
I keep going back to this chart/hypothesis:
-Josh
Good to know, thanks! Curious to hear about your 2 RM shutdown at some point.
As for the point about risking the Vacaville skip, I kept a close eye on projected range vs remaining miles from the very beginning of my 80 mph run.
i figured that it would be easy to adjust down to 75, 70, or even 65 mph if I got too close. Didn't need to in the end :)
- - - Updated - - -
You charge quickly, eat slowly (if that's why your stops were so long). My kids now have my S-85, my D comes in next week. Look forward to same kind of trip more southernly.
old geezer
Well, besides the Grants Pass where we actually ordered a meal, all the other stops were just made long enough to charge to a level where I was comfortable knowing we'd make it to the next supercharger while driving 10 mph over the speed limit.
- - - Updated - - -
Thanks, Marc!
I think it's still a mystery. I'd like to know the origins of this chart and how it applies to the P85D, if at all.
I'm not sure that graph is correct.
~76kWh is the usable capacity.
~80kWh is the design capacity. This is the maximum discharge point, at which the contactors will probably disengage to protect the pack. Or it's the point at which Tesla declare the pack beyond repair if it's been deep discharged.
~85kWh is the capacity when using the raw Ah figure x 3.7V x number of cells. Purely theoretical.
Zero mile figure is hidden by elevating Wh/mile. So the 265 mile range for S85 includes the zero mile protection, but the internal Wh per mile is set slightly lower so that if you go at the rated Wh/mile you will hit zero miles after travelling ~250 miles, at that point the pack is nearly fully discharged and is likely to stop driving the car shortly.
Happy new year everyone!
I'm back in SF and have more data to share:
PortlandDetroit Lake56.22:293:3551.14ºC/39ºF9127.04801,289Wet/Rain21ºC/70ºF
Detroit LakeBend78.64:165:5348.61ºC/34ºF12537.54771,922Wet/Snow21ºC/70ºF
BendKlamath Falls136.09:2912:0153.7-12ºC/10ºF16749.7365613Snow/Sunny21ºC/70ºF
Klamath FallsMount Shasta84.91:152:3563.7-3ºC/27ºF10430.5359-640Wet/Sunny21ºC/70ºF
Mount ShastaCorning109.13:154:4374.45ºC/41ºF12135.3323-3,218Dry/Sunny21ºC/70ºF
CorningVacaville113.75:186:5173.48ºC/46ºF14643.7384-177Dry/Dark21ºC/70ºF
VacavilleSan Francisco58.17:308:2168.311ºC/52ºF7221.5370151Dry/Dark21ºC/70ºF
It got really cold in Bend the last 2 days we were there... great for the snow though!
Detroit Lake10 (4%)189 (75%)17953.23 kWh0:3981.89 kW2ºC/36ºF
Mt Shasta12 (5%)179 (71%)16748.98 kWh0:3877.33 kW0ºC/32ºF
Corning58 (23%)187 (74%)12937.83 kWh0:3270.93 kW9ºC/48ºF
Vacaville41 (16%)186 (74%)14542.52 kWh0:3572.90 kW12ºC/54ºF
Yep I charged several times in Bend using the Tesla HPWC at the hotel we were staying at. I didn't record those charging events but remember I got at most just under 17kW (208V x 80A) of charge rate.
As for Klamath Falls, I stopped at an RV park and used one of their NEMA 14-50 plugs. I charged for 1 hr 7 min at an average rate of 8.26 kW, so I got a total of 9.23 kWh (31 rated miles). The ambient temperature was -4ºC / 25ºF.
