Can anybody explain what this max battery mode is and I use it?
However it causes battery degradation and will reduce the longevity of your battery, so Tesla advises that it should be used sparingly.
Hi Cynix: That is some interesting information. Can you please post a link as to where you read this from Tesla Motors? If you are on shore power, does the heating energy come from the shore power or the main traction battery pack? I will be getting a P90DL and would like to be "up" on the guidelines and warnings.... and how that actually works... thanks.
ARTinCT
Please see more information here: Max Battery Power setting in P90DL
I'm still waiting for v7.0 for my P85D, so I don't really have any first-hand knowledge![]()
i have 7.0 on my P85D and I'm pretty sure I haven't seen this option, I'll check again.
I do not believe that that the warning is intended to say that it will reduce battery life or cause degradation to the cells. I believe they are simply saying that you will consume electrons at a more rapid rate and that the battery will enter reduced power mode faster due to overheating more quickly.
I disagree. Heating the cells while they're at high states of charge definitely does cause accelerated degradation. This is a well known fact of the cell chemistry. Unless the pack is below a safe operating temperature I would never heat the cells.
Do you think that perhaps the MAX POWER function may take into account the current pack operating temperature and know, based upon that data point, that it does not have to heat the pack? For instance if the pack environment system was cooling the pack down already? Your thoughts? Or am I expecting too much from Tesla engineering??
But how hot. If it's no worse than a summer's day, then it's no worse than driving your car in LA vs Montreal.
Hotter at high SoC = more degradation.
Actually, Tesla/Panasonic's NCA chemistry is pretty tolerant of high temperatures... here's the research paper, examine the 2nd graph:
Development of High Power and Long Life Lithium Secondary Batteries
Note that the life cycle difference at 25 degrees C and 50 degrees C is roughly the same.
Ok but is the car faster or not?
