P90DL - Can Not Get Into Launch Mode
Discussion in 'Model S: Driving Dynamics' started by rpo, Nov 15, 2016.
  1. rpo
    rpo Member
    Washington
    I need help! I've read the user manual, and every post on here that I can find, and watched every video, but still cannot figure this out.
    My understanding is push on the brake with the left foot, then hit the accelerator once to the floor and let off, then it will show you are in launch mode. I know I then push the accelerator to the floor and let off the brake, but I cannot even get that far. The absolute moment I touch the accelerator with the brake already depressed, the car shows the error about both pedals depressed. It doesn't matter if I push the accelerator to the floor quickly or slowly, or hold it there for a second or not, that error just stays on the screen and it doesn't enter launch mode.
    I've also tried max battery power on and off, though others have said that does not need to be on in order for it to work.
    Any ideas? I'm at a loss after two weeks of attempts.
  2. MrRandyB
    MrRandyB Member
    Delaware
    I would ensure you are fully pressing the brake pedal and max battery power is on
    You need to be in drive and at a complete stop with the steering wheel straight
    Then fully press the brake pedal with your left foot.
    While still pressing the brake with your left foot, fully press the accelerator pedal with your right foot, then release the accelerator pedal.
    The instrument panel displays a message indicating that Launch Mode is enabled.
    Within eight seconds, fully press the accelerator pedal a second time to pre- load motor torque, then within four seconds, release the brake.
  3. AndreyATC
    AndreyATC Member
    New City NY, USA
    I think you do need max battery power on
    It doesn't need to complete warming cycle though
    Make sure brakes applied really hard while you floor accelerator briefly
  4. rpo
    rpo Member
    Washington
    I got it finally! My error was not letting off the brake after stopping, then pressing it again to start the cycle. Thanks everyone!
  5. brianman
    brianman Burrito Founder
    @rpo - I find your 2nd post incomplete. It's missing "and my reaction to the experience was..."
    • Funny x 2
  6. rpo
    rpo Member
    Washington
    Hahaha! It seemed a bit faster than before. To be fair, I live in Seattle, and the roads have been wet 95% of the time I've driven the car since I picked it up a month ago. I'm getting tired of it.
  7. brianman
    Take a trip to CA for the holidays. ;)
  8. scottm
    scottm Active Member
    Canada
    You can still launch in the rain.
    That's when this car really shines!
    ..only lose a couple tenths...
  9. WannabeOwner
    WannabeOwner Active Member
    Suffolk, UK
    I'm sure you are right about release-brake and press-again, but in case relevant I had that error when I first tried Launch Mode and the reason was that I was not "standing" on the brake pedal [enough]
    I don't use launch mode when demoing to friends as I think it gives the game away as the car hunkers down and grunts and groans on the brakes ... I do a countdown from 5 ... to ... 1 and I GO somewhere between 3 and 2 ... catches the passengers out every time :)
    For me the chances are that I'm not on Max Battery either ... its only half a mile from my house to a perfect bit of test road, and usually we are going out for a run because someone said "Can we", rather than that I had thought about it and got prepared.
    At a Drag Strip I'm sure I would want max batter and Launch Control etc. :cool:
