This morning I engaged the "Max Battery Power" option for the first time on my recently delivered P90DL. The user interface on the option is a bit clunky (the only real way to tell if it is ON or OFF is to see if it is in "Preparing" mode after you hit the button. I had driven the car modestly hard for about 40 minutes prior to turning it on (maybe 56 degrees outside) but it still took about 10-15 minutes more of driving before it indicated that it was heated up sufficiently to reach Max Battery Power status. I then zipped off from a light a little bit (it wasn't a good spot for gunning it for much above 45) and it did seem a tad quicker. I then did a u-turn and pulled into my San Mateo Supercharger station to plug in. I plugged in and a few minutes later I noticed that the car was making a ton of noise, basically the fans were blowing super hard. After about 15 minutes the fans slowly began to slow down. Stopped after 25 minutes maybe. I guess my question is how bad is that "Max Battery Power" mode for the battery over time? Is running the batter at that high-temp harmful? I have never heard the fans go on at all before even after a few Ludicrous mode starts.
-T
-T
