Actually, it won't be much of a noticeable difference at the drag strip. With launch mode engaged, the power reduction is only 1%. Without launch mode, the power reduction is 5%. The problem is that launch mode is really hard to engage on the street, and impossible to use during normal driving once you are moving.
I've tried using launch mode at stop lights and it is f'in hard to time it right. Before the update, I could just engage MB mode and whenever I wanted, floor the car and get max power.
Someone mentioned earlier, here's a graph showing the slow speed limits. I think it may not actually be traction limited at low speeds, but actually speed limited. I.e. You may be able to apply 1600A from 0 MPH, which would generate peak torque, but until the motor starts spinning fast enough, the voltage across the motor won't reach full battery voltage.
Or to say it differently, since HP = torque * speed, you can likely apply the nearly constant torque from a standstill, but won't get peak HP until the motor reaches a certain RPM. It seems like we don't reach the battery limits until about 40 mph.
That is why passing performance from 40 - 60 MPH is most impacted by the software update.
Anyway, here's hoping there is a resolution soon. It seems some owners are making some progress in negotiations.
