Tesla was quite about P85D fiasco, and probably will stay quite about this one too. Until someone sues them.
Where are the Norwegians when we need them !
Maybe that was the reason they've removed Ludicrous mode from existing CPO and inventory cars around August.
What is your source for the specific numbers you give above?Here is the deal..
This only impacts P90Ds. There is a lifetime counter on launches. However, to count as a launch a bunch of crieteria must be met:
1. Launch mode must be on
2. SOC must be >90%
3. Perfect traction must be maintained. Any amount of slip will cause power to be reduced and it won't count.
The limit is 25 for the rear drive unit. If this limit is hit, power is reduced slightly resulting is a difference of 0.05s 0-60.
Basically, unless you regularly take your car to the drag strip and can manage to maintain perfect traction while meeting all or the other conditions above, this is a non-issue.
I encourage everyone not to blow this out of proportion.
Here is the deal..
2. SOC must be >90%
Disliking for a lack of source. Either something needs to be dug up in the code itself, or Tesla needs to come out and officially state this.All I can say is it's accurate, and if we still had rep points I'd say "trust me".
Here is the deal..
2. SOC must be >90%
I'm unsure if this is accurate. @andrewket says the limit if for the rear drive unit... but that doesn't seem to fit with the data. The BMS is what specifies max current, not the drive unit.
The drop is from ~1600A to ~1500A (really like 1609 ro 1515 or something, dont have the numbers in front of me). That's significant. Comes out to roughly 40 HP.
It seems possible that the BMS says 1600 A max but the DU pulls less. For instance, a single motor 85 in the "base" config will only pull 1000 A while the BMS specifies 1200 A max. 1200 A is pulled by a DU in the "sport" config.
I'd love that, but I don't think they would do this as a replacement program. Maybe you mention this problem and beg or complain about this, they may do it on individual basis. I know they are doing extra things to keep people happy/quite.Isn't just solving the problem with low-cost upgrades into P100D's a whole lot better than waiting for a class action lawsuit (and concurrent bad press)?
Come on Elon, step up and fix this.
Now please.
Thx.
The data I've seen shows the advertised pack current dropping, not the max DI current.
Thanks Ingineer, great informative posts.
Since we're talking about battery capacities and launch limitations, could you also comment about launch limitation in 60/70/75 cars?
I drove a S75 and noticed that how slow was 0-60. Especially 0-30. 0-30 felt much slower than my old Bmw 630. It was like the car didn't want to move first 1-2 seconds.
Then I've tried 10-60, which really felt fast, even comparing to my P90DL, it was good. It is obvious that Tesla is limiting the power of S75 if you are doing "launch" from 0. Rolling start from 10mph is definitely much faster.
Have you got any data on that? Since lots of people have 60/75s, that maybe more interesting than P90D limitation for some people.
(Btw, in my opinion one reason that P90D is much more expensive than 90D is to cover the extra risk of drive train failure. If they are limiting launches, this is bad.)
