Jean-Claude
Former Vendor
The idea wasn't to see how accurate the sensors were in an absolute sense. The idea was to see if the area/sensor closest to the object varied with/without film on it.
I just want to point out that in the video you are measuring the distance from one sensor to the object, and coming up with 24 inches. The dash is showing the distance from the front of the car to the object as 22 inches. Since the nosecone is curved, the front of the car is, in fact, less than 24 inches from the object. I can't say if it is a full 2 inches closer--it's probably not. But I'm not sure why you would want to measure directly to the sensor when that's not the purpose of the sensor. The sensors, working together, are attempting to tell you how far the car is from an object. And since the portion of the car that was highlighted on the dash was the very front section, you should have been measuring from the very tip of the car, which would have resulted in the car's estimate being even closer than it was.
