Paint Smudge
Discussion in 'Model 3' started by chronopc, Jun 15, 2018.
  1. chronopc
    chronopc Active Member
    I noticed a small paint smudge on my driver door. I was thinking about taking it into the service center to see if they could fix it. Has anyone had any experience getting Tesla to fix paint smudges?
  2. Trevor B
    Trevor B Active Member
  3. chronopc
    It's on the right side of the handle. You can barely see it. I only noticed it because I was super close when I was wiping down the car.
  4. Thomas Edison
    Thomas Edison Active Member
    Portland-ish
    Can you circle it?
  5. chronopc
    It's pretty hard to see. I can totally live with it, but if it's a quick fix, I'll have Tesla fix it.
  6. itskv
    itskv Member
    San Francisco, CA
    Bring to Service Center, they will fix.
  7. chronopc
    I scheduled one for after I come back from my 4th of July road trip.
  8. CuriousM3
    CuriousM3 Member
    Los Angeles
    Is it still glossy with the clear coat or is that smudge underneath it?
  9. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    Just don't worry about it. Life has far greater risks and challenges.
  10. chronopc
    The smudge is underneath the clear coat.
  11. chronopc
    I'm not worried about it, but if they are willing to fix it I would like that.
  12. TheOtherPete
    TheOtherPete Member
    Honestly I would be more concerned about them making it worse if they tried to fix it : removing the clear coat, buffing the paint and then re-applying the clear coat.
  13. Barklikeadog
    Barklikeadog Active Member
    PA
    Then accept it as part of life and move on. bigger problems out there
  14. fseir
    fseir Member
    Honolulu
    Your smudge looks different than mine, but Tesla did fix mine, and I’m happy with the results. I think the risk is that they sub paint work out to a local autobody shop, so the quality of the work is dependent on that shop. If you’re lucky, the repair will be undetectable, but if you’re not, you could have a door that doesn’t quite match the rest of the car. You’ll have to decide whether the smudge bothers you enough to roll the dice... good luck!
    Light patch on paint just showed up today!
    Someone else posted their results where their fender ended up not matching:
    Another poor visit with Tesla Service.
  15. chronopc
    I think I'll just bring it in and ask them what they plan on doing to fix it and I'll decide then. I live pretty close to the service center so it's worth chatting to them about it at least.
