I was on a roadtrip and happened to capture my supercharging session with tm-spy. I connected my dec-2106 90D to an unpaired station (1b) at the Framingham MA superchargers. I had been driving for about 1 hour after my car sat in the 30 degree cold for about for about 8 hours. The battery temperature had reached about 66 degrees by the time I reached the station with about 10% left in the battery. The first picture I've attached is the entire session. As you can see, it starts off ramping slowly over about 7 minutes up to about 120kW. It slowly settled in to 112kW and stayed there for maybe 5 minutes and then started a slow taper. The second picture is blown up to show the step-wise change in charging which occurred later in the session. The first of two steps happened immediately when a model 3 connected to the paired station (1a) where my charging dropped from the 112kW to about 84kW. A couple minutes later it again took a step-wise change down to about 69kW. It seems that the "I was there first, give me all the charge I want" sharing method is not in force now.
