Unfortunately the penetration of the pvc and refrigerant lines is above the foundation wall of the garage - so about 9” above the slab. I measured from the top of the penetrations to the bottom of the roof overhang above and only have 72”. So would not meet the 80” height requirement you mentioned. Is NEC requirement 80” or 72”?As miimura suggested, I would do everything except rotate the regulator. Hold that back as an option if someone in authority says.what you've done is not enough.
How high off the slab are the refrigerant line penetrations? And the white PVC?
Cheers, Wayne
