Pano Roof Noise - Factory Fix Coming
Discussion in 'Model S: Interior & Exterior' started by sgblank, Aug 19, 2013.
  1. sgblank
    sgblank Member
    pescadero, ca
    Brought my P85 in to Menlo Park for service on multiple items, one of which was noise at high speeds on a closed Pano roof.
    Service said they adjusted the seals which may help a little, but then the rep said there's a factory fix coming to address this issue.
    The rep said the fix is pretty extensive and will require 2 1/2 days in the shop.
    My work order says "...will be coming out with a repair to fix wind noise - will be contacted when parts are available."
    The rep said the parts will available in about a month.
  2. wdimagineer
    wdimagineer Member
    San Francisco, CA
    Interesting. My car was just in the shop with this as one of my concerns. They didn't mention a forthcoming fix. But in the interim, I have no more whistling but now have lots of scratches on the trim piece in the middle part of the car that they're now going to replace.
    Here's the texts from my work order:
    Complaint Narrative: Perform SB-13-24-004 Panoramic roof creak bulletin.Cause: Panoramic roof needs updating to prevent noises
    Correction: Install Felt Tape, Inspect/Grind Crossmember, Inspect/Install Shims,Inspect/Back out Spacer Bolts, Inspect/Move J Clips
    Perform roof updates to prevent noises
    Complaint Narrative: Customer states that there is excessive wind noise while drivinghighway speeds. Check and advise.
    Cause: Gap between panoramic roof and sealing suface too large and causing wind noise.Correction: Interior NVH General Diagnosis
    Test drive vehicle verify wind noise. Remove panoramic seal, clean surface and installnew thicker adhesive to buffer wind noise. Calibrate panoramic roof.
  3. MarkR
    MarkR Member
    N. Scottsdale, AZ
    I can't fathom that he fix will require 2+ days to complete, but will likely put a huge burden on the service centers just given the number of pano roofs that are out there.
  4. fiksegts
    fiksegts Active Member
    Miami
    glad to hear a fix is in the works, mine is way to loud over 85 MPH...
  5. B-Chicago
    B-Chicago Member
    Chicago
    Had mine in 2 weeks ago for the pano creaking and noise at high speeds. Both problems started at the same time. Notes below. 100% better on the pano creak. 90% better on high speed noise (i have never had a targa top before, so assuming SOME noise at 85-90mph is acceptable, but maybe not).
    Complaint Narrative: Customer states: creaking and rattling noise from roof while driving
    Cause: perform bulletin to correct panoramic roof creaking.
    Correction: Panoramic Roof General Diagnosis
    Road test vehicle and verified creaking from roof area. Perform bulletin to correect panoramic roof creaking.
    Complaint Narrative: Customer states:excessive wind noise from pano roof at highway speeds
    Cause: Tab needed to be adjusted for proper fit of panoramic roof glass
    Road test vehicle to verify roof wind noise. Heard noise at the front of the roof above 80 mph. Per bulletin adjust front tab of sunroof to allow for a tighter fit. Road test vehicle to verify repair.
    also interesting to note:
    Complaint Narrative: Perform mandatory service bulletins
    Cause: service bulletins required by engineering
    Correction: Apply Loctite on C-Pillar Brightwork on Both Sides, Clean Area Per bulletin loctite on C-pillar brightwork.
    When I got my car back, the energy usage graph was off the charts high. I have no doubt they tested the car at 90 miles per hour somewhere (for a good 20 min from the chart). Someone at the SC had fun.
  6. texex91
    texex91 Banned
    hell
    That's not good for it.
    Did they fix it? And I'm assuming factory is now making this correction so new cars will not have issue?
  7. scaesare
    scaesare Well-Known Member
    NoVA
    How do you draw that conclusion? Mine came from the factory with a similar energy graph and I've been told that's a result of doing similar testing after the car is built.
  8. texex91
    texex91 Banned
    hell
    #8 texex91, Aug 22, 2013
    Okay let me re-phrase. Having someone floor my car in the shop multiple times would p*** me off. There.
  9. wiztecy
    wiztecy Active Member
    If the battery was not below 20-30%, the car is fine and it didn't do anything detrimental to the pack / car. Most likely they were road testing it and ensuring there's no other issues with the vehicle. I'd prefer a service technician flooring and pushing my car to the limits rather than babying it. They know what these cars are suppose to sound and drive like over a larger sample than your single vehicle only you have access to.
    If it was on the dyno that's fine too. Whatever they need to do to find an issue before I do is cool with me.
  10. NigelM
    NigelM Recovering Member
    Northern Virginia
    Ummm, they were testing for wind noise at high speed (which is what the customer complained about). What would you expect them to do? If they gave the car back and said "Well, we think we fixed the problem but you have to test it and bring it back again if it's not ok.", I think most owners would call that poor service.
    Note: Please also watch the language; this is a family-friendly site. Thanks.
  11. texex91
    texex91 Banned
    hell
    Got it thanks...won't happen again.
  12. B-Chicago
    B-Chicago Member
    Chicago
    I expected a road test and glad they did it. I'm not mad. A little confused at how the usage was as high as it was for so long though. I floored it multiple times on the way home on the express way and could only get it up to about 600wh/mi. They had it up to 900wh/mi several times. Picture below. I can't replicate that kind of energy usage. Glad to say my lifetime average is back down under 400 again though.
  13. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    With that kind of usage, I would probably ask the service manager what went on.
  14. B-Chicago
    B-Chicago Member
    Chicago
    Answer from SC. Makes sense if there is no mileage (ie almost infinite energy/mi if there is no mileage):
    [FONT=&quot]What we typically find is that the wh/mi rating shows abnormally high while the vehicle is on and using energy, and not logging mileage. This shows an unusually high number since no mileage is actually be driven and only energy is being used. I hope this is not too simple an explanation. If you still have concerns or would like clarification please let me know. [/FONT]
  15. brianman
    brianman Burrito Founder
    Keep in mind that measurements with units such as "Wh/mi." are quite sensitive to the denominator. Meaning at low speeds and high "exertion" you can easily spike some high numbers. For example, it's far easier (for me at least) to achieve ~1700 Wh/mi at 35mph than at 60+mph.
  16. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    The service center is correct. Next time you're stuck in traffic or going through a drive-thru with your A/C or heat on, it will peak at a very high value (like 900 Wh/mi for a bit). Wh/mi becomes very large when the denominator in that ratio becomes very small.
  17. huntjo
    huntjo Member
    Fort Collins, Colorado
    When I had my tinting put in, the numbers had a very narrow spike to 900 Wh/mi due to the doors being open and HVAC/ radio on th whole day. They did not drive it.
  18. Mayhemm
    Mayhemm Model S P85+ "Lola"
    Saskatchewan, Canada
    Heh heh. Good luck with the fix.
    The pano roof on my '02 C-class Merc was constantly squeaking, so I'd bring it in. They'd perform a new "procedure" to fix the squeak and it would seem to help. Then it would start up again after a few days. Rinse and repeat. I must have had the roof "fixed" half a dozen times over the life of that car. Each time was a revolutionary new fix that would definitely eliminate the problem.
    Well...10 years on and a different company....they might do it.
  19. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    I had the exact same experience. Next time she goes in, I will raise the question before they begin the work.
  20. Mayhemm
    This makes sense. My ICE car routinely has mileage of 99.9L/100km if I idle for an extended period.
