pano roof - vent position changed
Discussion in 'Model S: Interior & Exterior' started by phatman, Aug 4, 2015.
  1. phatman
    phatman Member
    Toronto, Canada
    Hi everyone -
    I noticed that after a software update about 3 weeks ago, my pano roof no longer went to the same "vent" position. The rear part used to raise about 3 inches above the car, now only literally just disengages and raises a crack. When I'm in the car and push the roof up, there's definitely another couple inches of give but it bounces back down.
    I called my service rep today and asked him about it and it turns out that this was actually part of the last update! If going to vent from the closed position, it'll only open a crack. If you vent from an open position, it will be bigger than a crack, maybe an inch and a half elevated. So I checked it out myself after he told me this, and yes, it's true. He said the reasoning behind this was that this was part of the solution to reduce wind noise.
    Has anyone else noticed this and any comments? I personally liked it better when it elevated 3 inches up, because then I can really cool my car down when "precool" it on these hot days. I'm not sure if any venting really happens when it's only open a crack.
  2. golfski
    golfski Member
    Seattle, WA
    I noticed this as well, but I thought it was actually malfunctioning. I had my entire pano replaced early on and have had on and off problems, so I just chalked it up to that. Good to know this is on purpose!
  3. rjcbox
    rjcbox Member
    PA, USA
    New owner here. Also feel the current minimal-vent setting is inadequate to cool a hot car. Although it'll use some energy, I wonder if Tesla could configure vents to draw air from outside into the car when the vent setting is used remotely, and push the hot air out. Before I owned the car, I actually thought I'd have same functionality (closed to full open) via the app
  4. scaesare
    scaesare Well-Known Member
    NoVA
    Yup, firmware related. Don't care for it either.
  5. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    I mentioned it to my Service Center a couple weeks back (when I was on 2.4.239 or .249). The advisor sat in the car and confirmed it with me and had me submit it as a bug report. I've since been upgraded to .253 and it's still there, as well as reports from those with 2.5.21 saying it has remained.
  6. scaesare
    NoVA
    I suggest we all report it as a bug via the voice command in the car...
  7. GlmnAlyAirCar
    GlmnAlyAirCar Active Member
    Sanatoga PA
    I suspect here is what happened:
    1. Driver opens pano roof remotely.
    2. Rain begins
    3. Driver forgets pano roof is vented.
    4. Interior of car gets wet
    5. Drive complains to Tesla
    6. Telsa reduces the vent position to minimize rain intrusion.
  8. mknox
    mknox Well-Known Member
    Toronto, ON
    I think mine was malfunctioning. It wouldn't open at all (not even a crack) on Vent, and when I would try to open it fully, about one time in three I would have to "help" it by pushing up on the glass at the back to get it going. Tesla replaced some components and now it does open every time, but "Vent" is just a tiny sliver.
  9. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    You don't need the roof to open much in order to vent. Hot air rises, so you only need a small opening to vent that air out of the car. The point is to get the hottest air out of the car as it rises, right? It's not to bring outside air into the vehicle.
  10. CTShore
    CTShore Member
    Westbrook, CT
    My question is this: Why did they not tell us about the change with the update? I'm on 2.5.21. Going in for first tire rotation tomorrow & will add that to my list.
  11. jerry33
    Texas
    Sort of. I found that if you just have it to vent, there is no cross flow and the interior stays hot. It's a lot cooler at 20% then at 12% (15% was ideal, but the got rid of that setting some time ago.)
  12. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    Holy crap, I thought I was going crazy. I kept thinking, "the vent position hardly seems open at all". I was going to make a service appointment thinking my pano roof needed a fifth visit to the service center.
    So what can we do about this?
  13. scaesare
    NoVA
    I reported it as a bug.
  14. vdiv
    vdiv Chief Grump
    Reston, VA
    Yup. But see, it doesn't rain in Cali so... What's the problem exactly? :)
    Because it would hamper the mystery experience and since knowledge is power it may disturb the balance, speed up your car, slow down the Earth's rotation, and give you an extra leap second of sleep ;)
    - - - Updated - - -
    Ask for an adjustable vent position. Also ask for programmable vent events (just blower, no A/C) akin to ICE BMWs
    If not crack open the windows or use the remote climate control.
  15. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    I wonder if the "NEW" pano roof (as of a month ago) design, exhibits this minimal vent opening? Perhaps TM adjusted the firmware for the new design and somehow the original pano only opens minimally?
  16. InsaneDriver
    InsaneDriver Member
    Miami, FL
    When I first got the car I tested cooling the car by venting the roof vs not. Very unscientific but what I found is that the car cools off quicker for me by not venting the roof.
    Many assumption was having the roof open would allow the hot air to escape and the cold air replaced it lower in the car.
    Just didn't work work that way, so now I just pre cool and leave the sunroof closed.
  17. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I thought the same thing. Good to know as well.
  18. FLDarren
    FLDarren Member
    Seminole, Fl.
    The Tampa service center told me last week this is part of the new firmware.
  19. PaulusdB
    PaulusdB Mayor Gnomus Vintage Limb
    Europe
    It is a malfunctioning part of the new firmware, yes.
    Why else would it say that the roof opens for 12%, where it in fact opens for 1%?
  20. smilepak
    smilepak Active Member
    Eastvale, CA
    First picture open vent from closed position.
    Second picture open vent from open sunroof position.
    So small it's useless
