Parked & plugged in (storage mode) energy usage?
Discussion in 'Model S: Battery & Charging' started by neroden, Oct 20, 2012.
  1. neroden
    neroden Model S Owner and Frustrated Tesla Fan
    Ithaca, NY, USA
    Anyone got a sense of this yet?
    This electrical usage is probably going to be dominant over the driving/charging usage some months. I'd like to be able to estimate it.
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Check out
    Charging Model S | Tesla Motors
    While this is for driving, sitting there plugged in is a fraction of that. I'd estimate maybe 1-2kWh per day but I'll take a closer look. The Model S doesn't have a storage mode like the Roadster does.
  3. neroden
    Ithaca, NY, USA
    Huh -- seeing this again, you guessed pretty good, dsm. According to people's reports (translating from "miles") it's about 2-3 kWh/day, without sleep mode.
  4. tezco
    tezco Sig P85
    Colorado
    I'm using about 4 to 5 kWh per 24 hrs, measured at the wall.
  5. nrcooled
    nrcooled P#8946 VIN 03225
    NoVA
    In Virginia we recently got some snow so my car has been sitting in the garage sleeping and plugged in. While I haven't measured the power output at the wall , the car has lost distance while sleeping. I noticed when I woke her up to check for the 4.2 update. I was at 241 rated miles when initially completed the charge. Two days later it was at 221 rated miles. If the car is indeed pulling power from the wall at 4-5 kWh a day where is it going?
    When I got in the car and woke it up it stated charging again and rose to 241 rated miles again. It doesn't seem as though my car is pulling any power from the wall when sleeping. This was on 4.1 (.31). I will observe what happens on 4.2 (.42).
  6. mknox
    mknox Well-Known Member
    Toronto, ON
    If the car was left plugged in for, say, a month would it just continue to lose charge all that time? Is there some point when the software says, okay time to top it up again? Or does it hold it at some optimum (for the battery) level at something like 60% ?
  7. tezco
    tezco Sig P85
    Colorado
    The car tops off about once every 24 hours, at least on software versions up to and including 4.1
  8. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    Keep in mind some of this is perceived loss of range because the pack gets cold. Many of us have noted that a cold pack indicates less range than actual until the pack warms up.
  9. dennis
    dennis P85D
    Silicon Valley CA
    I have confirmed that it has the same behavior on 4.2 (1.19.41).
  10. mknox
    Toronto, ON
    Thanks. On the same theme of parked and plugged in, if away on an extended vacation, are you better to leave it plugged in to the HPWC or a NEMA 14-50 or would it be better to plug it into a 120v outlet? Or maybe it makes no difference?
  11. jerry33
    Texas
    At home, I don't see any reason to not use one of the first two choices. At someplace like an airport, the 120V solution is better because it frees up the high power chargers for someone who really needs it.
  12. mknox
    Toronto, ON
    That makes sense. I've seen a number of J1772 charging stations that have a 120 v outlets as well like this one:
