Folks: My 2017 X has the separate caliper for I am not sure what. When one pushes the park button, the car shifts into park. What does that activate? Is it the same mechanism that "holds" your vehicle at a stoplight (whatever that is)? Does it activate the small electrically controlled caliper? When shifting into park, all you get on the instrument panel is "P". However, if you press and hold the park button, then the parking brake icon comes on. Presumably that is the small caliper activated. So if putting the car into park is activating the emergency/parking brake caliper, why doesn't the parking brake icon illuminate on the instrument panel. Prior to acquiring the X, my only experience is with ICE cars---auto transmission shift in Park, that's it. Rarely use the parking brake. Among other things, I want to understand if the parking caliper is getting any "exercise". If it isn't I suspect that there is a good chance it will seize. particularly with our snow/salted roads all winter. That's what always happened to my ICE cars through lack of use. I plan on brake maintenance this spring and am trying to understand if disassembly of the parking brake caliper is required.
Thanks to all that respond.
