Parking sensors allow front bumper to grind into parking block
Discussion in 'Model S: Driving Dynamics' started by JRMW, Dec 23, 2016.
  1. JRMW
    JRMW Member
    Minneapolis
    Good afternoon,
    New and probably stupid owner here.
    My car is 48 hours old now, and every time I try to park it the front bumper skirt grinds into the parking block and/or curb.
    The parking sensors say 35 inches, 30 inches, then GRIND the front bumper skirt is grinding on the parking block or curb.
    I think this is happening because
    -the Model S is SO low to the ground (My last car was Lexus RX 330)
    and
    -the parking sensors seem to not see curbs or parking blocks.
    is this common for your cars as well? or are my parking sensors not functioning correctly?
    it's irritating because at work the parking spot is diagonal to the curb... thus the right bumper skirt grinds even BEFORE the sensors get to 35 inches!
    I'm nervous about the first time I park in an area with a higher curb. Will my bumper rip off?
  2. mblakele
    mblakele pre-jackpot member
    SF Bay Area
    I've seen this in a few places, enough to make me cautious. The higher the curb is, the more likely the ultrasonics will detect it. Of course then you're more likely to see it in the rear camera too.
    Here's what my copy of the manual says:
    Limitations and False Warnings
    The parking sensors may not function correctly in these situations:
    • One or more of the parking sensors is damaged, dirty, or covered (such as mud, ice, or snow).
    • Object is located below approximately 8 inches (20 cm) (such as a curb or low barrier).
    • Weather conditions (heavy rain, snow, or fog) are interfering with sensor operation.
    • Object is thin (such as a sign post).
    • A sensor’s operating range has been exceeded.
    • Object is sound-absorbing or soft (such as powder snow).
    • Object is sloped (such as a sloped embankment).
    • Model S has been parked in, or being driven in, extremely hot or cold temperatures.
    • The sensors are affected by other electrical equipment or devices that generate ultrasonic waves.
    • Object is located too close to the bumper.
    • A bumper is misaligned or damaged.
    On that last point you could ask your service center to check your sensors and make sure they're calibrated ok.​
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Yes, that has been the case since the introduction of the Parking Sensors option (as part of the Tech Package) way back in 2013. It is still true today.
  4. JRMW
    JRMW Member
    Minneapolis
    Thank you!
    Very helpful!
    it seems that they'd configure the parking sensors in such a way that the bumper wouldn't grind on the curb!!!
  5. JRMW
    JRMW Member
    Minneapolis
    I certainly hope my rear camera won't see the curb, since here in Minnesota we do not back into parking spots!:rolleyes:
    (unless we're 120 years old or something)
  6. NOLA_Mike
    NOLA_Mike Grouchy
    Hammond, LA
    My experience:
    TL;DR - Stop before the dead man and don't rely on the parking sensors to tell you when. You will rip off the bumper cover if you get caught right on one of them. There's a recent thread around here of someone who did just that.
    Normal "dead men" or raised curbs are really too low for the parking sensors. However, I find it does detect most of them until you get about 12" away from them - then they have slipped "under the view" of the ultrasonic sensors and seemingly "disappear" from the park sensor view. If approaching slowly I usually stop right before they disappear from the sensors view (i.e., I stop before the front of my car is over the curb or dead man).
    On top of everything else, it seems that even if you have the air suspension and cautiously raise the car above the curb that often, after shutting off and leaving the car, the air suspension will lower itself. I don't know the rhyme or reason for this, if it used to do it on earlier firmware releases and doesn't do it anymore - since I don't pull the car over curbs anymore.
    Mike
  7. Derek Kessler
    Derek Kessler Active Member
    Cincinnati
    This.
  8. phaduman
    phaduman Supporting Member
    San Jose
    Key is to enter slowly for s/w & sensor to catch the curb/deadman early, before they disappear.
  9. mblakele
    SF Bay Area
    Or if you can: line up straight, then get out and use summon. Also handy if the best available parking spot happens to be in a deep puddle.
  10. artsci
    artsci Sponsor
    Timonium, Maryland
    That's why we developed the front/rear camera switch kit for the touchscreen. They've long been sold out but we'll be producing them again. Ready probably by March or so.
  11. Blissedout
    Blissedout Member
    Weston CT
    I think you will find very few first time Model S owners who did not scratch the nose on a curb or tire stop, once or twice. I think the delivery person should alert new owners to this issue.
  12. kavyboy
    kavyboy Member
    Spring, TX
    I do this almost every time I park, now. Plus one time as I was walking away I heard someone say "Dayum!", so that was fun. :)
  13. eye.surgeon
    eye.surgeon Active Member
    Don't park over parking blocks. Drivers of sports cars already know this. Parking sensors detect walls and other vehicles.
  14. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    I don't have anything fancy like Summon, but my trick is to pull in, then bring up the rear view camera and pull forward until it can barely see the lines. That's far enough into the space that my rear won't be hanging out, and I clear the bumper/curb. Doesn't work in a short space, but the S ain't a compact, so I avoid those sort of spaces anyway.
    • Like x 4
  15. McRat
    McRat Well-Known Member
    LA
    That mistake will cost you over $3000 on certain cars. Carbon fiber splitters can break.
    Your best move if you're going to use an exotic or similar on the street, is to either raise the suspension 1-2" or larger diameter street tires.
  16. pilotSteve
    pilotSteve Active Member
    Vancouver WA
    @artsci - I had your front camera on my 2012 Sig and I *loved* it! Not a trivial install (took one day with a car savvy buddy and it was done) but it works perfectly and is what kept my from bumping my nose. Get one, install it. you will LOVE it.
  17. Wilber
    Wilber New Member
    Mill Valley, CA
    JRMW: I am curious - why do you say you dont back into parking spaces in MINN? I am in CA and I had a similar experience two years ago when my Model S was new. Since then, i only back into spaces that have a parking block or curb. The advantage is that the rear of the car is about 1.5 inches higher than the front, so not nearly as easy to mess it up in the process. Of course, you also have the advantage of the rear view camera to give a good idea where things are. I generally stop just as the parking block or curb disappears from bottom of screen. You may also find that setting your mirrors to autotilt will help give you another perspective, but not nearly as important as simply looking at your camera image. ps - I am not quite 120 years of age.....
  18. CalBlue 85D
    CalBlue 85D Member
    SF Bay Area
    Your ICE probably wasn't detecting the blocks either, but the MS is lower and will collide with them. Parking sensors are really only good for tall objects like other cars or walls. Surround view cameras would be nice though......
  19. Scannerman
    Scannerman Member
    San Diego
    This probably falls under the category of 'Monday Morning QB', but I assume the adjustable suspension would prove helpful. For the record, I have that same problem with my Ford Fusion Titanium.
    Scannerman
  20. McRat
    LA
    The EPA and CARB have invested in supplier of front air dams.
    Seriously, the more ground clearance the worse the range or MPG becomes.
