Parking sensors don't report (or see?) low parking lot curbs
Discussion in 'Model S: Driving Dynamics' started by RDoc, Apr 24, 2015.
  1. RDoc
    RDoc S85D
    Boston North Shore
    A lot of parking lots have curbs/barriers at the front of the spots that are about 6" high. The parking sensors don't report these, presumably because the beam is going over it. I'm not sure how that could be fixed, but it's a problem. I wish there were a front camera that could see the ground in front of the car.
    Perhaps when the car was far enough back to see the curbs it could remember where they were and as the car moved show on the display where they are relative to the current position of the car.
  2. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    I constantly struggle with this. At about half the parking lots I usually go to the concrete bars that prevent you from rolling too far forward are so low that the front lip of the Tesla clears them, at the other half the lip scrapes.
    And on none of them the ultrasound parking sensors reliably detects them.
    I so wish Tesla had gone with a front camera :-(
  3. Barry
    Barry Active Member
    Colorado
    I usually raise my suspension to high in parking lots with curbs or concrete blocks.
  4. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    good idea but what about the people with coil suspension?
    and even if you do have adjustable it'd be nice if the system would warn you or auto adjust to high.
  5. RDoc
    RDoc S85D
    Boston North Shore
    Does it stay high when it's parked or drop?
  6. andrewket
    andrewket Well-Known Member
    I park nose out whenever possible.
  7. Tdriver
    Tdriver Member
    Palm Desert, CA
    I stop short of the curb. Works pretty weill.
  8. fiksegts
    fiksegts Active Member
    Miami
    if the Tesla is supposed to "park itself" and "be summoned" later on, those sensors must detect the curbs....
  9. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN 65513, Model 3: VIN 1913
    Redwood Shores, CA
    Yup. I raise it to High (and now, the car remembers) at both my workplace and in my garage (because of a steep driveway) and the car stays put in that position.
  10. breser
    breser AutoPilot Nostradamus
    North Bend, WA
    Car drops after it's been off for a while. So raising the suspension does not help with this.
  11. Duma
    Duma Member
    That is one of those nasty little details that make these glorious visions difficult in real life.
    Lots of evidence that the current sensors and/or the current programmatic use of those sensors does not deal well with curbs that can damage the car. While it could be be a programming oversight, the geometry and placement of the sensors make me think that it is an actual limitation of the sensors - they don't detect the curb when they are close.
    I suppose the sensors could detect the curb while further away and the program should extrapolate this when approaching the curb, knowing the limitation of the sensor, but I haven't thought about this long enough to think of all the ways this could result in false positives (e.g. a bump the car can safely drive over regarded as a curb).
    That is why I am willing to cut Tesla some slack and go with the incremental improvement approach. Then again, I am a software guy and appreciate what it means to say Tesla is a software company. I get that this can be confusing to people used to more traditional engineering.
  12. gg_got_a_tesla
    Redwood Shores, CA
    Is that your experience? I've verified several times that it's exactly how I leave it, at High, 8-12 hours later. Only after I go past the speed at which it's supposed to drop does it really drop.
  13. breser
    North Bend, WA
    I see my car drop all the time after I've parked it.
  14. deonb
    deonb Active Member
    Redmond, WA
    Same for me. Definitely doesn't drop. I would have lost my bumper a long time ago if it did.
    Sometimes when I get into the car, it complains about "suspension too high", but it doesn't drop until I drive.
  15. dandelot
    dandelot Member
    San Francisco
    Ours used to drop fairly soon and forget it was on High.
    And it would go down (from Std) before up to High,
    which was alarming when there was a curb.
    Now it seems to remember the setting much better
    (perhaps because now on 6.2 software?).
    Used to be, not driven 2-4 days and it would settle (in the garage)
    and on waking up to move (air susp rising) there would be a loud
    pop as the tires unstuck from the (smooth epoxy-painted) floor. Not sure that will
    still happen...?
  16. sorka
    sorka Well-Known Member
    Merced, CA
    I've noticed the same problem.
    So how is the MS supposed to self parallel park later if the sensors can't detect the curb??????
  17. Barry
    Barry Active Member
    Colorado
    Stays
  18. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    Why in the world would raising the car on its suspension affect the tires' contact with the floor in any way? Air suspension does not work by hyper-inflating/deflating the tires.
  19. RDoc
    RDoc S85D
    Boston North Shore
    Probably because it changes the suspension geometry (actually position) enough to stress the tire/ground patch sideways.
  20. Odenator
    Odenator Member
    Olympia, WA
    One trick to use if pulling perpendicular into a parking spot is to watch for the curb under the driver side mirror. Once you see it come into view under the bottom edge of the driver side mirror, stop and you should be a couple inches away from the curb.
