Also, I was puzzled by this statement in his explanation: “we discovered that, due to body side alignment adjustments in the factory, the bonded section of the joint was compromised and the welded section of the joint was weakened in some cars.” I understand these cars are practically handmade, but that doesn't sound like a well-engineered body — if you have to make adjustments to the alignment that are significant enough to compromise a welded joint, you've got problems. I would love a more detailed explanation, as well as visual evidence of what’s going wrong in the manufacturing process.
