Passenger Door Stopped Working... again.
Discussion in 'Model X: User Interface' started by SolarRoof, Jun 3, 2016.
  1. SolarRoof
    SolarRoof Member
    Phoenix, AZ
    Second time in two weeks. Won't open from outside handle or touchscreen. It does function from inside handle. I know Elon said there is a door fix update on the way. It cannot be soon enough.
  2. KaiserSoze
    KaiserSoze Member
    I'm sorry to hear that!
    In my experience, this is indicative of a part failure. The fix may not be in software.
  3. SolarRoof
    SolarRoof Member
    Phoenix, AZ
    They are coming on Monday and bringing a new latch mechanism.
  4. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    Doubt a new latch will fix it if it can open from the lever. Sounds like SW. See the thread about the guy that had to have his car towed 500 miles to a SC and they fixed it with a special reboot from inside the frunk.
    While you are waiting you can just try cycling it. Pull the lever to open, then pry it open all the way manually. Then close it with the door handle or pulling the level. Test the handle opening again. Repeat up to 10 times to see if it will open from the outside.
    Happened to me a number of weeks ago and I had nothing better to do while charging. Has not had a problem since.
  5. KaiserSoze
    KaiserSoze Member
    I had identical symptoms, and the SC fixed it by swapping the latch.
  6. XisLate
    XisLate Member
    Silicon Valley
    I have that problem too with my X. Like everything else with a Tesla, it doesn't happen every time, but often enough to be annoying. I plan to bring the car in for the update that I know is available.
  7. sfriedrich
    sfriedrich Member
    There are fairly recently re-designed latches and that's probably what they will be putting in. Tesla has been -great- about fixing problems and I always feel very well supported (I have a Nov 12 MS and a Jan 16 MX). I love my local team here in Rocklin and wouldn't trade them for the world.
