passenger footwell lights removal
Ok 20min after I posted I managed to get all the other ones installed.
The footwells were the hardest, and one door.
Passenger door I started with and couldn't get the lever on the wires undone. Had to use pliers and and a screwdriver to lower the lever and pull the wire away from the light.
Secret to the passenger light, assuming you don't care too much about damaging the oem, is to just bend the clips from the backside.
I honestly couldn't get it free. I tried even pushing in the clips on the side while pushing it out from the back and nothing... Oh well, I wouldn't need to install the oem ones again, but that might is a little beat up, probably will still clip in and work, but definitely looks like someone attacked it
