Passenger Side Mirror Won't Auto-tilt
FlyingCookie
249
291
Nashville, TN
Hi Guys,
I just got a 2014 P85 last week, and after washing/polishing/detailing, the passenger side mirror doesn't appear to want to auto-tilt.
If I manually tilt it down, it'll go back to its home position when I go back to drive, but when I put it in reverse it goes down about 3 degrees and then stops. The drivers's side mirror appears to be fine. I can manually move the mirror just fine, however.
Is this a common issue, and does it usually require replacement of the mirror? The mirror does currently have a protective film (not sure what brand) on it, and i'd like to preserve it. Hoping this is a reasonably simple fix.
Cyclone
Cyclonic Member ((.oO))
Jan 12, 2015
5,056
1,141
Charlotte, NC
Try 1) Rebooting both screens
2) Put it in reverse and while in reverse, move the mirror to where you want it to go permanently
3) Put it in park
4) Move the seat slightly and then back to where it was
5) Click "Save" on the driver profile pop-up you got when moving the seat
Hopefully that lets it save the settings. If not, call the Service Center on Monday.
FlyingCookie
249
291
Nashville, TN
Did this
Did this
3) Put it in park
Did this
Didn't do this...
I did this part, but not with moving the seat slightly.
Thanks for the help... I'll definitely give the SC a call if also tweaking the seat doesn't work. Wouldn't surprise me (with my luck) to need a new mirror.
