I went out to my 3 today to replace the cabin filters. Opened the passenger door, window dropped down an inch as usual so it doesn't hit the trim. Fine. Moved the seat back. Then the passenger window spontaneously went all the way back up (so now if I close the door it would hit the trim). At the same time, the center screen changed to displaying the charging screen and was stuck on that. I lowered the passenger window using the control, then shut the door, unplugged the charger, got in the driver's seat and tested it again... Every time I open the passenger door, the window would go down an inch as it should, but then then a second later would go all the way back up. I thought perhaps this was related to the new close windows on walkaway feature, so I disabled that. After disabling that, the window worked correctly on door open (i.e., it stayed down an inch), but only one time. The next time I tried it, the window goes down an inch for a second, then goes right back up. I did a two-button reset. Same problem.
If anyone has any ideas, I would really appreciate help. Leaving for a road trip tomorrow morning, and can't get a service appointment today. Uggh.
If I can't reset this, is this something I should call roadside assistance for (even though I'm at my house).
