I only see the passenger side window doing this, not the rear? I’ll have to double check.It's normal for all windows to readjust a bit lower when the car wakes up and it's cold enough outside. This might only happen as you open a door / unlock the car etc... Not sure of the exact trigger, but it's done that for years. Instead of keeping the windows lower all the time, they are only lowered when it's under a certain temperature (somewhere not too high above freezing). The target temperature is the thing that has changed with a software update maybe last year. Before that it waited until freezing, and by then it was too late.
I’ll have to look because I don’t think all 4 do that by me. Plus my passenger side door tends to rattle when I close my drivers side door which is what made me discover this. I have owned a ‘21 MYLR and now with the ‘22 MYP I honestly never knew this. I’m usuall lay really good at analyzing all updates that come out as well.All four windows do that to avoid window trim damage. Completely normal on frameless windows.
SE WI. It gets quite cold here, but I will have to check if all 4 windows do this. I only saw the passenger side do it so far.This one is temperature-specific which makes it more difficult to spot. Depending on where you live it could take a while before you get the effect.
See I am referring to something else. When I open my drivers side door that window slightly rolls down. At the same time when I sit inside and close the drivers side door the passenger window moves slightly down and up.Maybe the other ones are frozen and cannot move? Open the doors once first.
Yes, those are fine! ))I'm talking about the rear doors, which you think are not moving. Open them once to make sure those windows are not stuck / frozen, that's what I'm saying.
Oh I see. Yeah, now that you mention that. My Model Y does the same thing sometimes. I close the driver side door, and its window goes up (as it should). But then I can hear the window on the passenger side door go up as well, which does not seem normal. I do not think this happens every time.See I am referring to something else. When I open my drivers side door that window slightly rolls down. At the same time when I sit inside and close the drivers side door the passenger window moves slightly down and up.
Weird that mobile service told you that? Or weird that it is happening?Mobile service just told me it’s normal for the passenger side window to go down slightly and back up when the drivers side door closes. Because of the cold. It was an OTA.
I still find this weird.
Has anyone noticed whether just opening the Tesla app on your phone (and waiting for it to wake up and update the interior and exterior temperatures) will trigger the windows moving down? So for example, if it's 50F when I park, then later the temperature drops to 35F, and I open the app at that point, will the windows drop to the "freezing" position?When I park my car for the night, it may not be cold enough to activate the feature. All windows close completely. When I wake the asleep and now cold car up in the morning (because ambient fell below the trigger level), it will do this once the computer updates the outside temp.
My left rear window drops a bit when I open the drivers door and does the reverse when I close the drivers door. Odd
