Peak Charging Rate @ Superchargers - Model 3 Standard Range +
Vio1x
27
22
Toronto
Hi, just picked up a couple of days ago my new and first Tesla. So far I love it. I do have a question about v3 superchargers and 2021 Tesla Model 3 Standard Range +. What is the peak charging rate that this particular model can achieve? I've read conflicting info, where on one site, it says that model 3's can charge as fast as 250kW, while on others it says 150kW.
Question: in a perfect world (given ideal battery temps, outdoor temps, and close to empty battery) how fast could my 2021 Model 3 Standard Range + expect to charge at a V3 supercharger?
Also, could someone tell me what battery size comes in my model? is it 54kWh?
MP3Mike
15,327
33,241
Oregon
According to the specs listed on the Tesla site the Model 3 SR+ can charge at a maximum of 170 kW.
The Model 3 trim is not important for SC rates.
Wrong, it makes a difference. LR and Performance can charge at up to 250kW, while SR and SR+ can only charge at up to 170kW.
Vio1x
27
22
Toronto
Also, non battery related, I need some advise on a specific scenario. I went for a drive with my wife and son, and when I got to my destination I jumped out of the vehicle and my wife and son stayed inside the car. When I got back the alarm had gone off and music was blaring as my wife opened the door. I understand that’s the anti theft alarm, but in situations when I leave the vehicle but someone stays inside, how do I avoid the alarm if by mistake someone opens a door?
I don’t want to have to deactivate walk away locking. Any help would be appreciated
mrgoogle
100
67
Eindhoven
Depends on your battery, the made in China version with LFP has problems, 20-40kW peak is common. (Best case which is near impossible you average 40-60kW)
Reactions: cdswm3
elptxjc
752
143
El Paso, TX
The exact thing happened to us, when I accidentally deleted my wife's access card, which in turn deactivated her 'phone-as-key'. Without deactivating 'walk-away-locking', and/or 'security alarm', the only 2 ways to avoid that is either for your wife to download the Tesla app on her phone, you authorizing her access to the car (which she could track at any time), and setting her phone as key, while having the app active while you're away. The other is to give her the 2nd access card, and place it ahead of the center console lid, which basically keeps the car in 'ignition on' mode, ready to drive. I agree Tesla should make an update to avoid locking the car (or at least not activating the alarm) when people never left the car. There's a freaking 'selfie' camera there, plus movement and seat sensors, so it shouldn't be hard at all.
By the way, what the heck is the 'selfie' camera for? I couldn't find how to activate it, or what it's use is. Thx.
  • Disagree
Reactions: Gasaraki
LargeHamCollider
Battery cells != scalable
Jan 10, 2015
946
1,746
United States
Selfie cam is for monitoring passengers when in robotaxi mode (not something it can do now). It’s been suggested that it should be used for driver monitoring but right now it cannot be activated and is not being used for anything.
  • Disagree
Reactions: todd2fst4u
Gasaraki
1,514
1,004
Syracuse, NY
When you walk away and the car locks, can't you not just unlock the door via the app so the alarm doesn't activate?
The inside camera is not used yet.
todd2fst4u
204
145
Menlo Park, CA
The cabin camera can be used as analytics by Tesla.
elptxjc
752
143
El Paso, TX
There's an option somewhere to turn alarm on or off (security menu, maybe?). I have it ON at the moment. And I assume it turns on whether you lock the car with the app, manually, or with the 'walk away' feature.
Tslrsx
97
82
Antwerpen
If somebody is in the passenger Seat, they can tap the screen to wake It up, this Will keep the car unlocked, otherwise use dog mode or something.
Big Earl
bnkwupt
Jul 12, 2017
5,184
9,345
Springfield, VA
When you get out of the car, don't fully latch your door. Only closing it to the first click will keep the car unlocked and awake, with climate control on. I routinely do this when Supercharging.
Kymandu
17
4
Highest I’ve got is probably between 80 and 90 kw charge rate. Yes I routed to the supercharger 20 min before and drove beforehand. This was at 20% Soc at a 250kw charger. Leaves a lot to be desired
bobby g
216
113
The Inland Empire :)
Dog mode? My wife isn't, and I'm not implying, good for giggles and keeps temp but she has to be advised not to open the door. In a way it protects her, them, in the event someone else opens the door.
bobby g
216
113
170 would still be a V3 charger. I was pretty pleased with 188 yesterday but partly that was a low soc because Goleta was shut down and I had to go further than I wanted.
