Peak Output Show Off
Discussion in 'Roadster: Performance' started by suxxer, Mar 27, 2011.
  1. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    #1 suxxer, Mar 27, 2011
    Let us see your Peak Output Screens!
    Please add your type (sport/non-sport), model (1.5 / 2.0 / 2.5 ), tire type and pressure. I'm curious to see the individual peaks of each Roadster.
    My first attempt:
    Non-Sport / 2.5 (2010) / Yoko Advan Ad07 / pressure according to manual.
    (I was rewarded with this :eek::biggrin::rolleyes: - by the time I had the cam out, PEM/Motor already dropped down one yellow.)
  2. Talkredius
    Talkredius Member
    Hueckelhoven, Germany
    and please tire typ and tire pressure
    With my winter tires I get only 0,56 g, my wife says the reason are not the tires but my weight, she might be right:redface:
  3. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    Good point! Added the tire stuff
  4. Dragon
    Dragon Member
    Italy
    Then try accelerating going down a hill, you will get 0,76g! ;)
  5. doug
    doug Administrator / Head Moderator
    The please also include driver mass and waist circumference.
  6. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    Just got 0.68g and 260 hp.
    I'm missing 28 hp !!! (Specs say 288 hp)
  7. Eberhard
    Eberhard #421 Model S #S32
    Germany
    i got 229kW, that's more then the spec, but only 248hp. Does someone know the conversion rate? your image shows 270max, means only 18 left?
  8. TEG
    TEG TMC Moderator
    Conversion rate of what? Did you mean 229ftlb?
    229kW would be 307hp
    248hp is 185kW.
    If you want to convert ftlb to HP then you need to know RPM too.
  9. Eberhard
    Germany
    #9 Eberhard, Mar 31, 2011
    no i get up to 229kW displayed, if i switch over to the last screen with the peak values i only can see 248 hp. Do you make the conversion with 1.36? isn't this metric?
  10. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    I hit the 272lft evey time (272lbft is exact the number from specs). So I assume that the torque is limited - which brings out the old discussion about sport / non-sport only having only different firmwares...
  11. zack
    zack Member
    Minneapolis, MN
    Traction control setting?
  12. suxxer
    suxxer ElektroVolt
    Zurich, Switzerland
    I would be surprised if anyone has the traction control "ON" while trying to get max. output ;)
  13. kgb
    kgb Member
    Houston, TX
    #14 kgb, Apr 1, 2011
    Roadster 2.5 sport
    Traction control on (forgot to turn it off)
    Original tires front
    Toyo Proxes R888 rear
    Pressure (unsure... TPMS fault)
    Waist 33 inches
  14. rabar10
    rabar10 Model 3 >> Focus Electric
    Indianapolis, IN
    I can see the T-shirts now:
    "Show me your torques!" :biggrin::wink:
  15. Jaff
    Jaff Active Member
    Grimsby, Canada
    Do you get beads? :wink::biggrin:
  16. Dragon
    Dragon Member
    Italy
  17. Talkredius
    Talkredius Member
    #18 Talkredius, Apr 1, 2011
    me, new rims are to expensive, and I was lucky, that there was a curb which kept the car on the road but crashed the rims. Otherwise I would have tested how good the Roadster is at lawn moving.:wink:
    Things not to do with a Roadster.
  18. TEG
    TEG TMC Moderator
    Are you guys taking photos right at the moment of peak output, or is this showing a telltale of the max achieved?
    If it is "after the fact" what VDS sequence do you use to get that screen?
  19. strider
    strider Active Member
    NE Oklahoma
    #20 strider, Apr 1, 2011
    Here's mine:
    2.5 Roadster in Performance mode
    AD07 tires 33 front/45 rear
    TC on and off gave the same numbers
    250lbs person plus cargo
    TEG,
    The button that says "REAL TIME" above toggles "real time" and "max" mode which keeps the maximum values for that drive - I believe it's reset each time you power down.
