Pedestrian Warning Sound now in X? Wait, what?
Discussion in 'Model X: User Interface' started by forkee, Sep 9, 2020.
  1. forkee
    forkee Member
    Southern California
    Woke up this morning to this. Thought I had a leak in the A/C
    Anyone else unfortunate to this :oops:
  2. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    We knew this was coming (and your X is the first one I've heard) since all newly manufactured EVs are required to have it as of September 2020 in the US.
    When was your car built? You can always disconnect the speaker...or wait for the custom sounds that Elon has mentioned.
  3. forkee
    forkee Member
    Southern California
    it's a 03/16 build
  4. MorrisonHiker
    Colorado
    That's really interesting since the S & X don't have speakers in the same spot as the 3 and Y. Over the years, we've seen the speaker grille show up, then the wiring and then the speaker grille+wiring+speaker. Our Y from June 2020 has the grille+wiring but not speaker (until we added one to see if it would work).
    Can you tell where the sound is coming from outside? What firmware does your car have installed?
    Have you had the car since 3/16 or did you recently purchase it from Tesla?
  5. forkee
    forkee Member
    Southern California
    haven't had a chance to hear it from the outside. The tones resonate throughout the cabin making it hard to locate exactly where, but it sounds like it is coming from in back of the screen (weird, right?) the forward driving "whooshing" sound gets louder up to about 25 mph then softens up until you slow down, then it becomes annoyingly loud AF again. music doesn't drown it out.
    firmware is 2020.32.3 b9bd4364fd17
    purchased through Tesla used inventory early 2019. Never had this "problem" before
  6. MorrisonHiker
    Colorado
    Let us know if you can narrow down where it's coming from. Hopefully they aren't using the internal speakers to try to alert pedestrians outside. We have two Model S from 2017 but haven't heard it on them yet. Do you know if you are on 2020.36.3?
  7. sllvgl
    sllvgl Member
    San Francisco
    It does sound like a malfunction to me, it doesn't make sense that it would be so loud and uncomfortable from inside the cabin. Maybe try a reboot and see if the behavior changes?
  8. forkee
    forkee Member
    Southern California
    so just to follow up on this...
    i rebooted and it went away but every now and then it pops back up. i've chalked it up as a glitch that unlocks the sound. it is entirely internal as the sound is piped through the internal audio speakers (useless right?). adjusting the speakers does nothing, it overrides the music. since i'm the only known case, i've grown accustomed to this harmless novelty and don't see the need to bring it in for service. i'm sure if it becomes more frequent or permanent I would complain.
    upgraded to 2020.36.11 last week and still happened after. I did the infotainment upgrade last month though and I'm wondering if that has anything to do with it.
    here's another 5 minute clip of me just driving around
  9. Yinn
    Yinn Active Member
    Behind you
    You should bring it in. We're on the same software version and I don't have such a sound, I doubt it's intentional. Hopefully it's harmless but it would stink if it was indicative of a larger issue and you went past the work warrantied period.
  10. Master Chief
    Master Chief Member
    Norfolk, VA
    I haven't heard it emanate from my X but I heard something like it at the Supercharger yesterday. I think it was a Model 3. My wife's RAV4 Hybrid puts out the most God-awful sound, I truly thought her transmission was chewing itself up until I did some research. I understand why they do it but it doesn't make it right...
  11. zecar
    zecar Member
    New York/Chicago
    I now have pedestrian warning on the Y. It certainly doesn't resonate through the cabin.
    I don't know what that is, but I am somewhat concerned for Ray's survival.
  12. forkee
    forkee Member
    Southern California
    Happened again tonight. Decided to see if it worked during summon and it does :p
    I also confirmed it is not audible outside the car and only plays from the middle of the dash. Is there even a speaker there?
  13. MorrisonHiker
    Colorado
    Still odd how yours makes the nose inside the car.
    FWIW, we heard a new Model X at the Superior Service Center on Saturday and it was making the same exterior pedestrian noise that the 3 and Y make.
  14. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    I've heard on some vintages of cars that they have to re-pin the connectors when they do the MCU upgrade. I wonder if they got one of your internal speaker wires connected to the PWS output terminal on the MCU.
    While parked and playing music can you use the balance/fader and find a speaker that isn't working?
  15. BM3B
    BM3B “beaver”
    Los Angeles, CA
    I have a new X 9/2020 build with backup pedestrian warning sound. I don’t hear anything going forward from inside but haven’t tried standing outside.
    I know where the model 3 speaker is located and tested the disconnect on mine and it worked fine with a small warning icon on startup.
    Does anyone know where the X sound is coming from? I opened up the FR wheel well like the 3 and there isn’t a visible speaker there. I only see what appears to be airbag sensors.
  16. TeeeeeeDub
    TeeeeeeDub Member
    SoCal
    I believe it's in the front left driver's side bumper, in front of the wheel. Once i take delivery, i'm unplugging mine.
  17. wolly
    wolly New Member
    Tuesday
    CT
    I have the same issue. 2016 Model X, just completed an infotainment upgrade - and now i have this pedestrian warning sound only inside the car and occurs maybe 10% of the time. Currently service tech is telling me this is normal(?!)
  18. Yinn
    Yinn Active Member
    Behind you
    I've done an infotainment upgrade on a 2016 and I do NOT have this sound.
  19. Sunshine State
    Sunshine State Automotive Enthusiast
    Florida
    It’s clearly a glitch in the software if the sound comes from the interior speakers. My new Raven S’s have the external speakers and the warning noise isn’t even noticeable inside them. I traded in a late 2019 Performance 3 and the external speaker in that was much more noticeable inside the car, not obnoxious but more noticeable. I guess the S’s have better sound deadening.
