Only during charging. That's the rationale behind the Tattler's "cooldown" feature that starts charging at the lowest rate until the battery temp reaches a target and then reverts to your programmed time and rate.How warm is too warm for the motor? My OVMS is reporting mid 50s C when parked. It's not plugged in during the day at work. Just curious, if plugged in and not charging, does the Roadster use the wall power to cool things off or it only does with charging? Thanks.
That is not correct. We're talking about different systems.
The PEM and the motor are air cooled by the small fans at the back of the car. Whenever they ( motor or PEM ) are too warm, the fans run. After a run around the track the fans whirr until the motor and PEM are at a happy temperature.
I don't think the PEM and motor are cooled more aggressively if it is plugged in.
The battery is cooled by the liquid coolant which runs through the radiator with the big fans at the front of the car. Whenever the battery is too hot, those fans will run and the coolant will circulate. Sometimes the coolant circulates without running the fans. The "too hot" level is affected by whether you are charging or not, and whether you are in range, standard or performance mode. Obviously if the car is not plugged in, it doesnt want to waste energy you need to drive to cool the battery more than necessary.
When you are charging, the car will aggressively cool the battery according to your charging mode.
How does the air conditioning fit into your cooling scenario?
OK, my 11 month old v2.5 is getting Yellow PEM temps and corresponding "Power Limit" Dash lights everyday. Not driving particularly hard, though I do have a hill to climb and I get it there now regularly, but didn't earlier. Outside temps are in the 80's. This didn't happen through the summer last year. I believe the fans are working. I hear at least one fan running a lot of the time.
I'm thinking of accelerating my 1 year service and get this taken care of. I'm also thinking I could drop the bottom pan and clean things out myself. But then, I'm also wondering if anyone has removed the top PEM cover and blown out everything in there as well.
I'm pretty handy mechanically and would not hesitate to do this on any of the my ICE vehicles. Experiences, concerns welcome.
Idon't think that this a good idea. The Tesla service normally dismount the complete PEM unit before cleaning. That means, that you have to disconnect motor and battery. You don't have access to the cooling fins from the bottom of the car. I think I remember a thread from cinergi, where he had taken some pictures but don't find it at the moment.
Would I open the PEM? No because it will void the warranty.
