Perfect PSI tire inflator recommendations?
Alexandru
5
0
Hell
Hi guys, I am always trying to get all my tires symmetrically inflated to the same PSI when I drive my Model 3P. My biggest issue is that I have an inflator which takes quite some time to release from the wheel as I try to unscrew it, which causes some air to release from the tires and causes small asymmetry in PSIs sometimes. I was wondering if anyone has a recommendation on a quick release tire inflator (if such a thing exists) that I can just plug into my power outlet at home or plug into the car?
ewoodrick
5,285
3,721
Buford, GA
There are some things in life worth worry about. This isn't one of them. Carry to tire place and have them top off when needed. Most do it for free.
Alexandru
5
0
Hell
I appreciate it, but still wondering what kind of alternative tire inflators exist out there...surely there is something better out there.
Electric Dream
Pilots the Millennium Milkfloat
Jul 21, 2016
1,593
2,671
UK
Don't bother trying to use the inflator to get the correct pressures. Use one to inflate a few PSI over and then use a proper pressure gauge to set the correct pressure.
Paulussie
6
2
Nederland
Seems I'm not the only one with OCD :)
I use a pressure gauge like
The little button lets the air out slowly so you can have an exact pressure in the tire. How exact depends on the accuracy of the gauge :D
tcoombes
1,046
3,060
Northern California
Get a compressor (Amazon or wherever, they're not particularly expensive) and a Longacre inflation gauge.
I like my Husky portable ac/dc compressor with lever (not screw) valve attachment and ability to indicate the desired PSI (with .5 PSI incremental setting) prior to activation. It shuts off automatically when the desired PSI is reached. I always take into account whether the tire is hot or cold when indicating the setting. I usually plug it into the 12v port on the car, but have also plugged it into the wall on occasion. It’s very accurate, but I also really like a quality gauge to confirm.
Big Dog
1,502
1,500
Irvine, CA
exactly just get any new inflator -- without screw on cap -- and a handheld gauge. The air pump I use is ~30 years old and still kicking. Of course the gauge on it has never been accurate, as I have to pump it to ~50 lbs, which is 42 lbs with the handheld.
