A 5th generation Dodge Viper stops in ~90 feet. The Model 3 is 10% heavier but takes ~40 feet more. It's all brakes and tires. Wimpy tires will give you a reduced contact patch. And wimpy rotors / calipers will increase the time-to-lock-up and ABS to engage translating to longer braking distances. It's simple physics.
So yes, put in any of the following options and you will get a shorter stopping distance.
- Wider summer tires
- Bigger rotors
- Bigger pistons or calipers.
d = V2/(2g(f + G))
Where:
d = Braking Distance (ft)
g = Acceleration due to gravity (32.2 ft/sec2)
G = Roadway grade as a percentage; for 2% use 0.02
V = Initial vehicle speed (ft/sec)
f = Coefficient of friction between the tires and the roadway
Again, that's not true.
I encourage you to read up on the fundamentals of ABS. Short story is that ABS works by precisely controlling wheel speed relative to vehicle speed, which--most importantly--controls tire slip. It is explicitly not a binary thing--It is in the grey area between slip and no-slip that a tire enables the greatest braking force.
Road and Track said:When ABS is activated, this tells the onboard systems that your wheel has stopped rotating, meaning that you’ve exceeded the maximum stopping force of the tire. In other words, your stopping distance is limited by the tire. Your brake was likely perfectly capable of applying more pressure, however the tire lost grip, so more pressure serves no purpose
Similar to how adding a bigger steering wheel on a vehicle, a longer lever arm on a torque wrench, or any other similar situation where a bigger thing adds more precise control, larger brakes [in an all else equal system] will allow the ABS to more precisely control that tire slip and thus better maximize traction. Which of course reduces braking distance.
Brembo said:At the speeds that stopping distance is generally measured from (60 to 70mph), the test is primarily testing the tire's grip on the pavement. As delivered from the manufacturer, nearly all vehicles are able to engage the ABS or lock the wheels at these speeds. Therefore, an increase in braking power will do nothing to stop the vehicle in a shorter distance. For this reason, we do not record stopping distances at this time. The Brembo systems will show their greatest advantages when braking from higher speeds, or when tasked with repeated heavy braking.
Stoptech said:The brakes don't stop the vehicle - the tires do. The brakes slow the rotation of the wheels and tires. This means that braking distance measured on a single stop from a highway legal speed or higher is almost totally dependent upon the stopping ability of the tires in use
Its physics, as it were.
Haha. The Dodge Viper has 295 width front and 355 width rear tires that are "Streetable Track & Competition" tires. They have the bare minimum amount of tread to be DOT legal.A 5th generation Dodge Viper stops in ~90 feet. The Model 3 is 10% heavier but takes ~40 feet more. It's all brakes and tires. Wimpy tires will give you a reduced contact patch. And wimpy rotors / calipers will increase the time-to-lock-up and ABS to engage translating to longer braking distances. It's simple physics.
- Bigger rotors
I think you missed the part where he mentioned wider/sticky tires as one of the things that decrease stopping distance. And brake response times are still relevant. Any delay in the pads getting full grab on the rotors is still a delay regardless of rubber compound.Haha. The Dodge Viper has 295 width front and 355 width rear tires that are "Streetable Track & Competition" tires. They have the bare minimum amount of tread to be DOT legal.
I don't think the response time of the brakes has anything to do with it.
I agree.I think you missed the part where he mentioned wider/sticky tires as one of the things that decrease stopping distance. And brake response times are still relevant. Any delay in the pads getting full grab on the rotors is still a delay regardless of rubber compound.
I think we can all agree in a one-time, emergency braking event, larger rotors/pads may not make much measurable difference for most daily driving uses. However, larger and/or high performance brake systems absolutely make a significant difference on the track or under any sort of performance driving. Decreased brake fade, increased surface area to volume ratio for better heat dissipation, potentially less unsprung mass, etc., all play a role.
A performance car without equally performing brakes is nothing but a poser-mobile in my opinion. Why spend 80k on a performance car that can't do anything but drive around in city traffic? If it's being advertised (via Elon's twitter as of late) as a trackable car, then it will absolutely require larger brakes than the base model.
Can you explain, specifically, how "bigger rotors" make any difference in delay time of the brakes in any way that impacts stopping distance?
Absolutely.
Big brakes make zero difference stopping once in a panic stop from highway speed.
They can make a tremendous difference when stopping the 10th time in a row from 150 mph though.
But it's worth noting even then- the difference they make is that they keep your stopping distance nearer what it was the first time since they're a lot harder to overheat.
They still don't ever make it shorter than the first time.
Given 99% of folks don't track their cars
Just pointing out for the vast majority of owners who don't take it to a (non drag) track, that upgrade doesn't actually do anything for them.
And just watch and see if Tesla makes the "sport brake" option available on the non-P models later and people who also never track their cars waste $ on it thinking it'll help in normal use... (I know tons of folks who do exactly that with ICE cars that offer brake upgrades they'll never benefit from).
Careful... That's cost to produce, not cost to buy.Everyday recently there is something that shocks me about Tesla.
Elon tweets that if they were able to produce 10K model 3's per week...….the price could definitely come down to $28k.
Teslas inability to produce cars in numbers costs the customer?
Tesla Model 3 teardown points to only $28,000 in potential material and production cost
I don't agree.Careful... That's cost to produce, not cost to buy.
Elon is agreeing that at that 10k/week rate, Tesla's profit on the $35k car will theoretically be ~$7k. It doesn't mean they will be reducing the price of the car down to $28k for consumers.I don't agree.
They are talking about total costs.
That is a particularly good article - IMHO. thank you Garlan.Everyday recently there is something that shocks me about Tesla.
Pulled out of the air? Really?You cannot make a Model 3SR as promoted by Tesla for $35k. Something has to be surrendered. It was a price pulled out of the air to claim superiority over competitors. It had no bearing on costs. Or they are making 50% on every Model S/X and are hiding the cash in Krugerrands in a Boring Company tunnel, or it's orbiting in a SpaceX orbital vault.
They pulled a price out of the air - and told it as fact to shareholders and investors...….?
Elon was on stage and without the Tesla board knowing or anything.....just spewed forth " $35k.....yeah.....that sounds good".
Just a quick thank you to all those willing to pay for performance options.
These options help Tesla income and therefore P&L - and helps to starve the gas guzzler production/sales.
And eventually improvements trickle down to the rest of us.
My '89 turbo Saab 165hp; 22-24 m/gal. city; 34-36 m/gal. highway; (used to be quick) 0-60 about 8.5 seconds - snail pace today
Seems near the pinnacle for ICE machines. read below
Consumer Reports finds small turbo engines don't deliver on fuel economy claims
They had no idea what the nVidia Drive PX system would cost. Hint, it's more than the $8k charged for AP 2.5 + FSD.
They had no idea what batteries would cost in 2019. The price did not fall as much as hoped for.
The first clue was Elon claiming a mass-produced 60kWh car must cost $46,500. "The Bolt loses $9000 per car" were his words. If anybody knows what a 60kWh car would cost it would be Elon.
That German article, based on the LR premium model, proves just how wrong you are.
