Anyone tried similar and had any issues? Anyone compared efficiency to the 20" OEM for the 3P?
Anyone get Tesla to sub a 19" OEM rim for the model 3P 20" OEM?
To give an update with regards to my setup that you quoted, the efficiency compared to the stock 20" wheels set wasn't astronomical. I would say negligible gains during the cold season. Reduced maybe 20 Wh/mi on average with the tires and the rim design I picked when spring came around where I knew consistent numbers I can compare between the PS4 & AS 3+.. I remember that it's a struggle to make it over 100 miles on a single full charge up to 90% SOC on both tires. Probably due to the fact that I have to run the heater a lot due to having a child in the back seat for comfort.
The 20" wheels are specially designed for the bigger brakes and rotors whereas the 19" wheels are not. So last I checked in 2018, they're not interchangeable. The 19" runs need a lip design to accommodate the mounting change.
Edit: got a PM from you, so I'll answer it here in case anybody else would like some additional information. As for rim protection, I won't be relying on the abnormal sizing to protect the rim in case of a curb rash. I basically reminded my self to avoid making tight turns and take the time to make wider turns to avoid curb rashes to the rims. Better to rely on rim protection to avoid curb rashes. Rimblade and the likes should give reasonable protection. I looked into then before, but decided against them for the time being.
Currently, I'm pleased with the tires & rims. They're very similar to the PS4. If I had to keep one set of tires and wheels, it wouldn't be the stock 20" wheels. 19" wheels set looked more unique and would last longer due to higher wear rating on the AS 3+.
The tires do not rub or interfere with anything I can tell. Clearance is about the same. Definitely recommend these tires for lite snow handling that the PS4 aren't rated for.
