SammichLover
Banned
Not sure what you mean by this.
That's why I added the explanation below it.
P.S. A Better Route Planner is only a shadow of reality. Arguments made based on those numbers are highly suspect.
I hope so. Driving in 10 degrees on my trips to Denver from KC forced me to spend upwards of an hour at each SC.2019.12 says "nope".
To be fair that's in temperate weather. During a cold snap your charging time may be double that.
You do tend to be somewhat longer between endpoints BUT that time isn't actually useful at the end with the ICE anyway, as you're recovering from the effects.
I do both for unfamiliar drives. A Better route planner to get an overall idea, and then the in car Nav for the trip.I guess some people find driving fatiguing. That's not the case for me unless it is terrible weather. The quiet and solitude of long drives is something I really like and tires me out a lot less than a day at work. I'm sure I'll do the trip in the Model 3 soon enough to feel the difference.
Are there any good route planners or do you just get in the car and go using the onboard nav and charging recommendations?
The battery estimates in car are usually a little optimistic for me, but only by about 2-4% SOC remaining. So I just make sure to charge a little more than recommended to be safe. Also because I like to drive fast and not have to slow down to make it to the next stop.
To expect substance from you? Maybe there's more issue with the 20" rims than I'd expect (I've never ridden on them) but on 18", with Pilot Sport 4S or MXM4, an 800 mile day trip in the Model 3 is like quiet trip to the grocery store. It is just flat out phenomenal at long trips. 350 mile trip to family that I used to semi-dread with the Camry XLE Hybrid, now it's a just-do-it thing without the fatigue washout to get over at the end.
Family friend, who works in marketing for dealerships and generally reels off a fairly healthy complement of ICE talking points, doesn't even try to take on this.
Like I said, I rode in all 3 models before I purchased mine. I couldn't tell my co-worker that the car is so damn noisy in the rear. As a driver or passenger, it isn't as noisy. Also as mentioned, the car is fine for your grocery hopping needs. It isn't as comfortable or quiet as my ICE cars for long trips. Noise after a long trip causes fatigue.
Not wrong, that was my exact experience. And no "not knowing enough about Teslas" wasn't a problem, my battery was warm. It's just that I needed 200 miles of range to ensure I'd make it through the next 100 miles. Maybe your car is magical and can still get 310 miles in 20 degree weather with the heater on while driving at 75. Alas, mine is not. Being condescending sure is fun!Wrong. It was in 20F weather, because my charging stops were all during the trip, i.e. when my battery was already at operating temperature.
EDIT: prior to .12 release, and if you knew enough about Teslas, and specifically Model 3....you could always add 5-10mph to your speed once you were close to the Supercharger to ensure it was warm enough. That was my trick. Tesla added in the on-route warming trick, which will actually use less energy in the long run. So that's nice.
I commute in mine (60 miles a day, sometimes 120). It's hardly a problem, it's not like it's temperamental or anything like some fast cars are.
If you like going fast then get the Performance. I don't regret it at all.
I think Autopilot offsets the small negatives in longer trips. I've come to enjoy being "forced" to relax and actually make my travel part of my trip. It's far less stressful (and healthier).
I will tell you the dual motor is VERY fast for regular driving. If I had the cash I would have ordered the P though, because why not?Well the used Performance I was eying sold. So now it's back to a $10,000 difference between the two. I think I'd be happy either way, but definitely want to try and go for the P3D.
depends on when it was built, too. they've cut down on wind noise, and if not...there's aftermarket products you can buy.
I'm still going to suspend disbelief that any part of an EV is louder than any ICE. But hey, you defend Camry to the death, good sir.
IMO people overestimate Tesla wind/road noise because there isn't an engine to help drown it out. That said, I have an august car and I definitely have some wind noise issues that I'm having Tesla look at. I'm sure it's a simple gasket issue.I'm not defending anything. But you seem to claiming one over another without actual test rides. What do you think is the noise while driving on the road coming from a 2018 Camry vs a 2018 Model 3? Your disbelief is only because of what you experienced yet not even the same model years to compare.
What do you think I'm talking about in terms of noise? engine? For f... sake I'm talking about road noise.
Yeah, I must have just dreamt it all that it blows away everything I've had before, not even in the same ballpark, in terms of fatigue. Coincidentally top-of-the-line Camry included.Like I said, I rode in all 3 models before I purchased mine. I couldn't tell my co-worker that the car is so damn noisy in the rear. As a driver or passenger, it isn't as noisy. Also as mentioned, the car is fine for your grocery hopping needs. It isn't as comfortable or quiet as my ICE cars for long trips. Noise after a long trip causes fatigue.
Lots of little things it can be. Some mirrors have whistling, particularly below highway speeds. Some windshields not quite match their roofs all the away across, I needed to address that myself. It was fine on the driver side but not the passenger side.IMO people overestimate Tesla wind/road noise because there isn't an engine to help drown it out. That said, I have an august car and I definitely have some wind noise issues that I'm having Tesla look at. I'm sure it's a simple gasket issue.
This is something of an issue, that optimal BEV cabin environment management is different than ICE. Primarily because of all the "free air heat", which is waste heat that gets tosses otherwise anyway. It isn't base operating knowledge of effectively everyone from decades of experience.I use my seat heaters. It's not magic. It's included in the price.
