Performance Plus Upgrade?
Discussion in 'Model S: Ordering, Production, Delivery' started by ToddRLockwood, Sep 24, 2012.
  1. ToddRLockwood
    ToddRLockwood Active Member
    Burlington, Vermont
    In today's Model S review in Wired Magazine, there was mention of an upgrade to the suspension on Elon Musk's personal Model S Performance, referred to as "Performance Plus." Here's the text from the article...
    "Tesla loaned us a Model S for four days. But it wasn’t just any specimen off the lot — it was Tesla co-founder and CEO Elon Musk’s personal car. This means two things. First, it’s outfitted with a revised “Version 2″ air suspension, along with half-inch-wider rear wheels, revised suspension bushings and end links, and Michelin PS2 sport tires. This could be offered as a “Performance Plus” upgrade for the standard Performance Model S, and is based on feedback from both Musk and his engineers." -Wired Magazine
    Does anyone have any information on this possible upgrade package? Perhaps in the 2013 model year? Different size wheels on front and rear would complicate things slightly. Although it's often expected in supercar territory.
    Review: Tesla Model S
  2. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    I seem to recall them mention that betas and rc's used for demos by reviewers did not have finalized components installed.
    My guess is that Elon's did.
  3. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    How can he do this to us? I just got mine yesterday:smile:
  4. ToddRLockwood
    Burlington, Vermont
    Perhaps it will be available as an upgrade.
  5. KenEE
    KenEE P1937 Reward Excellence!
    Texas
    It's mainly just an extra 20mm on the width of the rear tires. Tesla told me about this way back when Edmund's reported the 265's (instead of 245's) on the rear. Everyone assumed they were wrong, but when I wrote Tesla they told me it was an alternate performance option that they were considering to offer.
    I don't have the specs on the rims but you can probably just stick on some 265's on your first tire replacement.
    Ken
  6. Lyon
    Lyon 2016 S P100DL, 2016 X P90D
    Eugene, Oregon
    http://www.insideline.com/tesla/model-s/2012/2012-tesla-model-s-signature-performance-suspension-walkaround.html
    You're right, the rear wheels on the Performance Plus package are wider but are, at this point, still prototypes.
  7. jerry33
    Texas
    You can, but the tire will work best if the rim width is the same as tread width, so mounting it on the same wheel as the 245 tires isn't going to give optimum performance. Now if you aren't concerned it won't be a problem (you'll only notice the difference if you actually measure the performance) but then why bother? Having different size tires front and rear adds cost and complications.
  8. KenEE
    Texas
    Thanks for chiming in. I've put wider tires on several times, but for asthetics not performance.
    Once my S's tires need replacing, I plan to locate some 20" rims that are very similar to the stock 21's. But at 20 I'll have many more tire choices.
  9. contaygious
    contaygious Active Member
    Marina, San Francisco
    "That upgrade is currently being tested and we have not decided if this will be released to our customers or soon-to-be customers in the future. Therefore, backwards compatibility is yet to be established. The performance car is an amazing vehicle as-is, and the additional gains from our proposed “upgrade” would only be seen if you are seriously considering using the car for track events."
  10. 7racer
    7racer Member
    usually adding more rear induces more understeer which makes it harder to rotate the car for track events.
    Unless, the car is heavily rear weight biased like a Porsche...
    What is the weight distribution on the S? 50/50?
  11. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    I think they have said 48:52 weight distribution.
    Understeer / oversteer can also be adjusted via the sway bars.
  12. 7racer
    7racer Member
    yep and/or tire pressure.
  13. alset
    alset Member
    Boston
    Let me save y'all going through the full list of corrections for understeer. :p
    OVERSTEER / UNDERSTEER CORRECTIONS
    I like the idea of keeping the same tire all around for tire rotation simplicity.
