Performance (red) Brake Calipers for 2017?
kimbahpnam
40
15
PNW
Just for clarification, there's no oem performance (red) brake calipers for 2017 that I can add to my '17 MS 75? Is my only option to have them painted/powdercoated?
dds28
41
13
Honolulu
Unless there is a way to retrofit the Brembo calipers to the post Nov, 2016 cars, you options may be limited to painting the calipers. The later cars have sliding calipers with the electric parking brake in one unit. If there is a way use the Brembo calipers, you will still need to add the separate parking brake caliper from the earlier cars. Not certain if the suspension knuckle is the same for both earlier and later cars. Also the wiring harness for the earlier car parking brake might also be different than the later cars.
