Sadly yes, on my 3rd one now in 8 months (this one looks like its sticking !)Anyone with a performance 3 have their spoiler coming away? It’s the second time it’s happened, I mentioned it on a service visit and they changed it.
Now dirt gets in the corner and when it rains or I wash the car, the dirt streaks down the car.
View attachment 556634 View attachment 556635
Just improve the look of your car by taking it off?
Kind of joking there. If mine does the same I'll be happy. As ugly and unnecessary as the spoiler is, given it's part of the car I'd be unhappy if it just came off. I'd also be in the service centre to fix it. Don't see why I should DIY fix something that is a warranty fault.
There are no guide pins on the 3.
I put my spoiler on with the below tape and adhesive promoter (it held with amazing strength instantly) but i didn't like that there was a slight gap maybe a 1mm between the car and spoiler in places. I feel like water runs off the trunk and works it's way into the spoiler adhesive so eventually the corners give.
I put silicone around the top edge and corner. The bottom I left open. It's hard to see in the pictures because the bead is flush or slightly under the spoiler. I taped it off and spread it out. Then just took a paper towel and my finger nail to make the bead under or flush. The silicone is easy to wipe off the trunk before it's dry. It comes up with paper towel. After it's dry you can peel it off if you want.
There is no movement of my corners at all now. Time will tell how long this holds but it's been about a month already.
https://www.amazon.com/dp/B006QYB3JG/ref=cm_sw_r_cp_apa_i_IMwnFbVS4Z449
https://www.amazon.com/dp/B00B3I1JR6/ref=cm_sw_r_cp_apa_i_.MwnFbM1MD7ZP
https://www.amazon.com/dp/B000AL6WLA/ref=cm_sw_r_cp_apa_i_eOwnFb1300JT0
View attachment 575821 View attachment 575822
Which one did you get?I fitted the carbon after market one to my LR & its solid as a rock, but I cleaned the boot carefully with meths first. It's fixed with what looks like 3M tape!
