My point is as you make a car more powerful you are supposed to improve its braking
Why?
Usually when people make this claim it's because they don't understand what the brakes actually do, or what actually stops the car.
Once you move your foot from accelerator to brake, the car doesn't care how many HP the vehicle puts out.
Unless you're running the car on a race track (and I don't mean a drag strip) or you're involved in the chase scene from a Bourne film, there's no benefit to "upgraded" brakes.... and that's true
regardless of the power of the car.
If you
are racing on a track then there are benefits to upgraded brakes that are true
So either way power doesn't change anything.
But again- that benefits all cars, regardless of power.
And since the car isn't traction limited even with the stock 18 all seasons, the "more power" thing is irrelevant here again.
and beef up the suspension as necessary to make use of all that power.
Again, this simply isn't a limitation on even the non-P suspension...and there's no evidence at all that the P+ suspenion does anything useful to "make use" of the added power- since again, the P+ and P- cars put up about the same actual performance numbers.
Agreed on the the aftermarket but potentially voiding the warranty on a car such as this is a scary proposition considering the battery cost, etc.
It's also an imaginary proposition since that's not how warranties work.
I suggest you google The
Magnuson-
Moss Warranty
Act
Changing your tires or shocks won't have any impact whatsoever on your battery warranty.
As for the 0-60 stuff, if the times on Primacy tires are the same as the PS4s then the size and weight difference may be off-setting it somewhat but I have a hard time believing it.
Great thing about facts are they remain true even if you don't believe in them
Tons of folks have tested both the P3D- and P3D+.... and some have even swapped PS4S tires onto the 18s....none of it made any significant difference to 0-60 times.
Because the car
is not traction limited regardless of the wheel/tire combo.
As for overall tire performance, here was a quick test done between the 18s and the 19s on the Model 3 and it showed improvement in acceleration, braking and lateral grip.
I already said better tires would improve braking and handling- that's true
In fact the car in your video is the LR RWD- the slowest Model 3 on earth at the time the video was made.
Their 0-60 testing seems wrong though- the 18s were slower than even Teslas listed time for the car (with 18s) and we know Teslas times are all sandbagged except for the P...most car mags were testing that car (on 18s) in the 4.8-4.9 range...miles from the 5.3 they measured.
I suppose since they were testing a 2WD version of the car there MIGHT be a traction limit compared to AWD cars- but I've never seen any other evidence of one, and again everyone else on earth who tested the RWD with 18s got much faster times (as fast or faster than they got with the 19s)
